Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
    Jul 2006
    No need to re-balance after vulcanizing
    Yes, bofeor dismounting the tyre, what the tireman would do is mark the exact spot on where the tyre valve is located. Upon tyre mounting, he will just position the tyre valve on that mark.
    Wheel balance would still be ok, IMHO.
    Jul 2013
    ^worse case scenario, may problem yung tire.
    Kelan mo sya binili ang gaano na katagal yang problem?
    Sent from Zenfone 3 on Tsikot mobile app
    Sep 2014
    Mag 3 years na yung car ko at ngayon ko lang napansin ng mag check ako ng tire pressure.
    Sent from my SM-G920F using Tapatalk
    Sep 2014
    Safe pa bang gamitin yung tire wala namang singaw yung pito.
    Quote Originally Posted by grand kotse View Post
    errr... whypo? is there something inherently wrong with your tire?
    from what i understand, the problem may be the pito and not the tire.
    so, yes! safe.
    Sep 2014
    so, yes! safe.
    I mean puwede pa bang itakbo yung kotse kahit may problema na yung pito baka kasi magka leak pa yung pito kung hindi ko muna sya palitan
    *grand kotse
    pwede pa itakbo yan ... basta punta ka na lang tire shop asap
    maganda siguro pa-check mo na lahat ng tires mo ... kasi 3 years mong nakaligtaan
    Sep 2014
    Quote Originally Posted by kinyo View Post
    *grand kotse
    Hindi naman 3 years regular naman akong na che check ng tire pressure at ok naman lahat dati. Ngayon ko lang napansin na may problema sa pito.
    Tanda ko nagpatire rotate ng huling pms kasama yung reserve at yun ang tire na nagkaproblema. Hindi kaya class B ang mga reserve na gulong he he?
    Anyway ibinalik ko na lang sa reserve yung tire at ipa change ko na lang yung pito next week. Thanks guys.
    my concern is, that pito might be causing erroneous readings, resulting in a vastly over-inflated tire. when used on the road, it might weaken the tire's carcass, resulting in the so-called "oblong". when that happens, the tire would be next-to-useless, as it won't be "comfortable to use", if not dangerous.
    why not use the spare tire in the meantime? bring the questionable tire to the tire shop.
    Jul 2017
    normal wear and tear ng gulong yan bro
Tire Pressure Question
