Safe pa bang gamitin yung tire wala namang singaw yung pito.
Sent from my SM-G920F using Tapatalk
*grand kotse
pwede pa itakbo yan ... basta punta ka na lang tire shop asap
maganda siguro pa-check mo na lahat ng tires mo ... kasi 3 years mong nakaligtaan![]()
my concern is, that pito might be causing erroneous readings, resulting in a vastly over-inflated tire. when used on the road, it might weaken the tire's carcass, resulting in the so-called "oblong". when that happens, the tire would be next-to-useless, as it won't be "comfortable to use", if not dangerous.
why not use the spare tire in the meantime? bring the questionable tire to the tire shop.
Hindi naman 3 years regular naman akong na che check ng tire pressure at ok naman lahat dati. Ngayon ko lang napansin na may problema sa pito.
Tanda ko nagpatire rotate ng huling pms kasama yung reserve at yun ang tire na nagkaproblema. Hindi kaya class B ang mga reserve na gulong he he?
Anyway ibinalik ko na lang sa reserve yung tire at ipa change ko na lang yung pito next week. Thanks guys.
normal wear and tear ng gulong yan bro
Use a proper tire pressure gauge to check the tire pressure instead of the tire pressure monitor ...
Saan po ba makakabili ng proper tire gauge? I live in the provice kasi. Just got my new car and planning to get one.
handyman/diy/ace sa mga malls ... meron lagi tire gauge ... kahit yung mumurahin (<P300) lang pwede na, tama reading, ewan lang sa tibay![]()
