uyy, ok ito ah. ako din i plan on making a trip down south...manila to samar to be exact. good luck to us both 'adre, haha.
civic ek a/t? torn between two cars ako, i have one like yours, and a manual cr-v. gusto ko civic dalin kse a/t, pero gusto ko din yung crv kasi powerful tsaka maluwag, kapagod nga lang lalo kasi manual.
anyway, if i were taking my civic, ganito check ko:
1. fluids - oil, brake, coolant (very important. summer kasi you don't want your coolant boiling off in the middle of nowhere in 34C heat).
2. engine valve clearance - if you follow PMS like the previous owner, the casa may have done this for you na. be aware of any weird noises in the engine now...weird noises sometimes turn into full blown mechanical problems if you run the engine for hours on end in very humid, high rpm conditions.
3. a/c and tint - sure they look fine, pero the a/c could suddenly go because it has not been maintained for a while, and the sun, if you don't have any installed tints, will burn your arms and face and cause you tremendous fatigue. trust me on this...i ran manila pagudpod with no tints...i felt like i crossed the ****ing sahara when i got there.
4. high octane gas - don't believe the horsehit about 93 unleaded giving you more kilometers per liter...high octane gas will burn more slowly, evenly...that is why you feel more hp at the dynobutt when you load up on velocity or blaze or whatever. you get savings at the pump with 93 unleaded, pero you do have to stop more frequently.
5. run a couple psi over the minimum tire pressure recommendation - the tire will have less rolling resistance, giving you better throttle response/fuel economy. downside is medjo matalbog ang ride.
6. blast your air filter with compressed air to clean it - a clean air filter will give you a bit more hp, period.
7. a/t fluid - use only atf-z1 from honda. mahal pero the tranny will only work with this fluid.
hmm, haba na nitong post...dami pako naisip eh pero its more of the usual. good luck on your trip pre...the ph16 engine in your civic is a sturdy engine...it will not let you down, provided you take care of it.
