Results 11 to 20 of 37
- Dec 2004
- 10
December 13th, 2004 02:34 PM #11was able to replace my timing belt at CAMEO TBA Center (BF Paranaque) okay ba dun compared to other shops in the area?
December 14th, 2004 06:49 PM #12
napo91,
nakapag palit ka na? anong mga pinalitan at magkano lahat ang gastos mo?
- Dec 2004
- 10
December 22nd, 2004 09:49 AM #13Total Cost (parts and labor) : P7,900.00 ++
This includes:
timing belt
A/C belt
alternator belt
tensioner brng/belt
power steering belt
idler brng
water pump
cam/crank oil seals
utol ko nagbantay, so hopefully nakabit naman lahat ng items.
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 28th, 2004 09:53 AM #15around 3-4 hours for the belt. kaya naman hintayin pero it might be better to leave it lalo na kung papalit ka din mga fluids, etc. 1 day tho tapus lahat yan assuming you bring the car early
September 10th, 2005 03:27 AM #16
HELP!! i have a 2001 vti-s honda civic with 32,000km. my leak na ang engine oil. pina check ko sa rapide, they said i need to replace the gasket/seal and obligado mag palit daw ng Timing belt and Tensioner...... is that normal? kailangan na bang palitan ang belt and tensioner? or just oil seal lang? thanks
hope you can give some advise.
- Jun 2005
- 325
September 10th, 2005 08:52 AM #17I think you don't have to change your timing belt yet since only 32T km pa lang.
Did they diagnose where the leak came from? From the oil pan ba, or baka maluwag lang ang drain plug mo kaya tumutulo ang oil. Pag from oil pan - they will just remove this and put another gasket (palinis mo na rin kung may konting sludge pagtinaggal yung oil pan). If from drain plug - all you have to change is the aluiminum washer (o baka kailangan lang higpitan). Either way mura lang to.
May mga mekaniko na palpak: na-oovertighten yung drain plug at na-loosethread pag oil change - kaya tuloy tumutulo.
I hope the leak is not from other parts of the engine.
September 10th, 2005 10:30 AM #18Originally Posted by jaeger
- Nov 2003
- 3,849
September 11th, 2005 05:37 PM #19depends which seal it is, kung dun sa may timing belt, and nabasa yung belt mo ng oil, it is better to replace it.
September 11th, 2005 08:14 PM #20Originally Posted by speedyfix
ang hirap kasi minsan sa mga talyer. kahit seal lang ang papalitan, they will tell you to change the other parts. anyway, do you have any recommended shops for this kind of service? mas maganda kung expert sa honda. thanks
I went with him at LTO's The Link satellite office nung nag-renew sya. We were given a number to...
