ahem ahem... hehehe!![]()
ano pa nga ba ? .... SpeedyFix ka na.... heheheh... Honestly they've done a great job on my Civic's timing belt few months ago. Highly recommended ...
Hi Benchp1, im due for timing belt replacement, Honda pasig quoted 15T for 80Tkm checkup which includes timing belt replacement, replacement of of all fluids (transmission, gear, engine, etc), oil seals + 5T more if water pumped is replaced. Im looking for cheaper alternatives if i have it serviced at reliable shops around marcos hiway/sumulong area, looks like yung dalawang shops mentioned: Speedyfix and H3 Autoworks are near...would you have contact/address of these shops?Originally Posted by benchph1
nandon sir sa Sig ni Speedyfix ang phone number ng shop nila.. Tawag ka na lang... Kay Sir Speedyfix ako nagpa 80Kms checkup and Timing belt and water pump replacement. Orig timing belt and GmB waterpump + some seals. less than 10K lahat ang gastos ko ng labor + materials. Parang half day lang ginawa ng mga tauhan ni Sir Migs.
Sir corection lang po. ALABANG PARTS CENTER po yun name ng shop. peace!Originally Posted by happy_gilmore
Pag due na ba for replacement ang timing belt kailangan na rin palitan yung ibang parts like seals, water pump, tnsioner, fluids, belts? or pwedeng palit timing belt lang para mura?
for the most part when it's a big job like the timing belt, it's better to replace all parts at once.
assuming you replace just the belt, then the tensioner starts making noise, labor ulit.
or if the waterpump leaks or oil seals leak then ganun dun labor ulit. replacing things together makes for less hassle and less expense in the long run![]()
salamat sa feedback... kumusta naman yung quality of work nila?Originally Posted by wrcastro_ph
Nagpalit ka rin ba ng ibang belt like napo91?Originally Posted by wrcastro_ph
Is it recommended to replace the other belts aside from the timing belt as part of the 80Tkm maintenance?Originally Posted by napo91
you only replace the other drive belts kung may bungi or tama na. no need if they are in good condition.
How much are the following quality parts for Honda civic 94 hatchback 1.1L engine
1. Timing belt
2. tension bearing
3.oils seals
4. valve cover gasket
5. distributor O-ring
6. water pump
For me, better change the belts that are inside the engine, yon mga fan belts, alternator, aircon belt, at least kita mo if needs replacements na, timing belt di kita, palitan mo na lahat para isang bukasan na langIs it recommended to replace the other belts aside from the timing belt as part of the 80Tkm maintenance?
sir speedyfix, pwede po ba mag-quote ng labor and materials cost for timing belt/tensioner (orig and replacement part) para sa 96 civic vti? maraming salamat...
does changing timing belt needs the engine to be out of the engine bay of the car?
naka bili ako timing belt sa casa. tataka ako chinese yung sulat. yung do not bend sa plastic. parang nilagyan lang yata ng code ng honda. made in japan yung sticker. yung timing belt china?
