Results 41 to 50 of 57
June 13th, 2007 04:45 PM #41
Sir DJ and Sir Yebo,
Don't stop discussing. I will post many questions for you through a new thread. I hope you will not take things personally between each other and spoil us the oppurtunity to learn from you and what you have to say. I am just a humble graduate of Diesel Mechanics and Automotive Mechanics.
You guys have two varying experiences. Military and Gas/Oil all exposed to harshes conditions and equipped with only the best training, equipment, machines and people. In your field any failure means lives and millions of $ lost.
Regards
Juan Ramon Landas a.k.a 4JG2-TC(4jgtootsie)
- Sep 2006
- 51
June 13th, 2007 05:06 PM #42I take my hats off for d_j, yebo, otep and the rest of the guys here. Thank you very much for your sincerity to help. Your inputs really raises the bar of education we all can get from this forum. very well appreciated except those whose inputs made some "patutsada" that left some bad taste. vert enlightening and much appreciated. I'll just keep my options to myself.
- Sep 2006
- 51
June 13th, 2007 05:09 PM #43I take my hats off for d_j, yebo, otep and the rest of the guys here. Thank you very much for your sincerity to help. Your inputs really raises the bar of education we all can get from this forum. very well appreciated except those whose inputs made some "patutsada" that left some bad taste. very enlightening and much appreciated. I'll just keep my options to myself so I can at least help douse off the heat.
June 13th, 2007 05:13 PM #44
Ikaw ang magaling Galynxmo!
Napalabas ang mga nasa palaispan ng mga taong ito! Goodluck bro kung ano man ang maging desisyon mo.
June 13th, 2007 05:29 PM #45
Sir DJ,
Gusto ko sana mag test ng L2 can you give some insights.
Gapang ako sa composite vehicle reference booklet and daming data.
June 13th, 2007 06:13 PM #46
Sir DJ,
- Oct 2004
- 278
June 14th, 2007 01:20 AM #47
To give the other guys a better understanding, eto po yung naka-highlight sa post ni sir yebo.... (Toyota 4A thermostat assembly)..
1. one from the water pump
2. one going back to the engine block (water pump suction line)
3. another going to the radiator OR coming from the radiator (some engines kasi before radiator ang thermostat galing engine block, some naman after ng radiator ang thermostat) .
4. Don't mind this. It is from airconditioning heater (di ko sya kinabit kasi walang ganun yung evaporator ko) - the other end is connected sa engine block, near water temp sensors (blocked).
I hope this somehow helps pa...
***Feel free to bash me of my post if i've got anything wrong....
June 14th, 2007 01:41 AM #48
Good morning sa lahat lahat
dyan ako bilid sa mga master tsikoters.......dami mo matututunan.........
ito lang share ko baka makatulong.........
June 14th, 2007 09:13 AM #49
No bashing!
The pictures i think is an example of an open/closed thermostat. The simpler type. Sir Yebo's more complex type involves two thermostat located on the same housing.
I took a picture from a book pero sobrang pangit
It is on a Cummins N14 and Series 60DDC.Last edited by 4JGtootsie; June 14th, 2007 at 09:31 PM.
June 14th, 2007 12:21 PM #50
if you have an advanced diesel experience then you should be golden. all it is (L2) is electronic/fuel/air induction/exhaust diagnostics (diesel)
a good understanding on how to read schematics would be really helpful. try understand how each respective system works and their basic concept rather than memorizing. if you have any specific questions, hit me up at driftoholic1*gmail.com or start a new thread, I'll be more than willing to help out.
Xiaomi E-Car
