Results 11 to 20 of 57
BANNED BANNED BANNED
- 3,790
June 10th, 2007 09:57 PM #11....that removing your t-stat would make that much of a difference given that you are in a warm climate area...
June 10th, 2007 10:08 PM #12
Tsikot Member Rank 4
- Jun 2006
- 2,605
June 10th, 2007 10:23 PM #13I don't think that removing your t-stat would make that much of a difference given that you are in a warm climate area.
June 10th, 2007 11:55 PM #14
OT: If only I had the time, I'd be your classmate at Meralco sir userfriendly. Kaso hindi ko talaga ma-fit sa schedule.
June 11th, 2007 03:54 AM #15
I suggest replace by new one mura lang naman yan at napakahalaga sa auto natin yan baka nag malfunction or makitid na clearance nya pag nag-open not like the retracktion of new one, range of opening from 20 to 25mm new thermostat
http://i178.photobucket.com/albums/w...G_0331copy.jpg
June 11th, 2007 06:10 AM #16
I'd argue all day but about this, but opinions could only go so far... first off, most factory analog gauges are dummy gauges (not that accurate) but it can definitely tell if you're engine is over heating. Most engines' normal operating temp would be around 180deg F, an engine's cooling system minus the t-stat wolud still get plenty warm (even on a freeway/hi-way). Also ECU/ECM's doesn't read signals by the digits... but via paramaters sent by a temp switch, normally the same switch that controlls the fan; and if the ECU/UCM doesn't get that signal, it would raise the engines idle to get the signal but that would not prevent it from producing it's "max power" (you get power from fuel, air, spark, exhaust flow).
And that would be the only drawback of not having a t-stat in a tropical climate, a few minutes of higher idle which converts to less than a teaspoon of gasoline.
An engine can never be too cold unless you are in a real cold climate (somewhere around less than 40deg F). And unless you have a double row aluminum radiator, under driven waterpump, higher pressure radiator cap, aero dynamic tested front fascia to create low pressure underneath the engine and running a waterless coolant (NPG) in your cooling sys, the only drawback you would get from not having a t-stat is a longer high idle during start up.
I am not recommending to go driving around without a t-stat but his question was somewhere along the lines of "would it be a big deal if..." by all means put it back on but like I've said it wouldn't really matter since the "stop and go traffic" together with the warm climate will ensure that your engine will reach max operating temp (even higher). Make sure that you keep up with the maintenance 'cause overheating can warp aluminum engine heads.
...and yes I am a mechanic, I've been serving as a vehicle technicin (7 level/craftsman) for the USAF for 6.5 years now
and one last thing, no it does not get that cold over there... you might've been just used to a warm climate so when the temp drops a few degs than normal, your skin shoots signals to your ECU (brain) and convinces your body that it is cold. it's all in your head j/k
Toyota is my choice
- Aug 2005
- 2,063
June 11th, 2007 06:54 AM #17how about those replaced thermostat from carb engine sir otep? is old rotary thermostat good?
- 3,790
June 11th, 2007 07:29 AM #18not to flame D_J pero I would only believe your claims if you have better educational background and better experience in car design and manufacturing than those who did those cars that we see today in the market (and also marketed world wide)...
afaik these experienced and properly educated engineers have been designing these engines to contain these sensors (like the humble thermostat) because of the specific needs for fuel efficiency and power output.
- Jun 2006
- 2,605
June 11th, 2007 09:21 AM #19
June 11th, 2007 09:35 AM #20
Are we talking of the same engineers that designed the 4JX1-TC? There are times that engineers forget to understand long term effects of their design.
And leave the humble mechanic to do task of doing repairs and remedies for their faults.
When i was still studying we had a classmate who was an engineer. I asked him bakit pa siya nagenroll engineer na siya. He said nabilib siya sa classmate niya na mekanico na nag engineering.
I find DJ's claim reasonable. Have you experienced a shut closed thermostat? It can blow your cylinder head and render it RIP.
Userfriendly, how is your class doing? kamusta mo ako kay sir Roger S. Hindi ko na kayo ulit nabisita.
Xiaomi E-Car
