Results 1 to 16 of 16
    Jun 2007
    I drive a 97 Honda Civic Lxi. My normal engine temp is about midway through the temp dial.
    However, I recently noticed that whenever I drive at NLEX and go above 100kph (around 2,800 rpm), the engine temp starts to rise rapidly. When I reduce speed to around 90kph, the temp needle returns to the normal level.
    I don't experience this when driving around the city or driving a low speeds. I've not attemped to push it for fear of overheating the engine. When I check the water level at my destnation, everything is normal. There are no leaks in he radiator or the hoses.
    Any idea why this is happening?
    Thanks.
    Dec 2003
    clogged cooling system or probably a near-busted waterpump...
    May 2007
    Understanding engine temp.
    Usually, thermostat start opening at 80-85C and is fully open at 90-95C.
    Your fan switch is on ar 90-95C and off again at 85-89C.
    Under normal conditions (outside temps <25 deg. centigrade and good airflow through radiator) the thermometer on the dashboard should be just over 70. If it goes towards 90, the radiator on the thermostat is bad. In exceptional cases the waterpump may be bad. Only extreme circumtances(very high outside temps, long climbs, no airflow to through the radiator) does meter go to 90. Even the coldest days or rainy season, the temps should reach at least 70. if not change the thermostat.
    Jul 2006
    I'd say thermostat is bad. Easier and cheaper to replace first than radiator. If thermostat is replaced and still does this have radiator checked, cleaned and pressure tested.
    Nov 2003
    you radiator is clogged. replace it imo.
    sir speedyfix is ryt, na experience ko din yung ganyan sa nlex, pero after overhauling the radiator nasa C na lang temp ko at di na tumataas.... goodluck.
    Feb 2005
    +1 ako kay sir speedyfix, most probably clogged yung radiator mo kaya di maka-circulate properly ang coolant during high speeds...
    try mo ... flushing mo radiator mo ... kung ndi talaga kaya bumili ka nalang ng bagong radiator ... manual costs aroung 2800 and automatic costs around 4800
    BANAWE A/S
    regy
    have your thermostat/sensor checked. i had to replace the sensor of my accord last year coz of calsification of minerals from the water.
    and if your losing coolant/water, have the radiator and the valves where the hoses are connected checked for leaks.
    Oct 2007
    1. Check you thermostat / sensor
    2. Cleaning of Radiator
    3. Pressure test
    4. Pls check also the belt kc baka lang naman maluwag or luma na, pede ding kasi maging dahilan since at high RPM maaring magslip yun belt mo sa pulley ng water pump mo, so di ganun ka effective yun delivery ng water pump mo. Good luck
    Aug 2006
    clogged radiator yan. either ipa overhaul mo yan o palit ka na lang.
    Aug 2005
    pagkatapos lahat ng sinabi nila sa taas at hi-temp ka parin baka minor leak sa cylinder head gasket kana. baka naman nagoverheat kana dati kaya may tama na cylinder head gasket mo sir
    Agree ako sa mga advice check them all.
    Another possible culprit is the oil level, quality, passages and filtration.
    Remember water temp is equal to oil temp.
    Less oil means hotter engine. Oil level maybe good but circulation is poor.
    Jun 2007
    Thanks everyone for your advice. Really appreciated.
    Jul 2006
    just check your radiator performance, paclean mo na kung matagal nang di nalilinis
    Nov 2003
    in some cases din the thermoswitch becomes faulty. it turns the fan on late na and only for a short time. try to replace that sabay narin.
Temp rises at 100kph
