Results 11 to 16 of 16
Zombie
- Aug 2006
- 728
October 20th, 2007 10:01 PM #11clogged radiator yan. either ipa overhaul mo yan o palit ka na lang.
October 23rd, 2007 12:40 AM #12
pagkatapos lahat ng sinabi nila sa taas at hi-temp ka parin baka minor leak sa cylinder head gasket kana. baka naman nagoverheat kana dati kaya may tama na cylinder head gasket mo sir
October 25th, 2007 10:45 AM #13
Agree ako sa mga advice check them all.
Another possible culprit is the oil level, quality, passages and filtration.
Remember water temp is equal to oil temp.
Less oil means hotter engine. Oil level maybe good but circulation is poor.
October 28th, 2007 04:44 PM #15
just check your radiator performance, paclean mo na kung matagal nang di nalilinis
Tsikot Member Rank 5
- Nov 2003
- 3,848
October 30th, 2007 11:02 PM #16in some cases din the thermoswitch becomes faulty. it turns the fan on late na and only for a short time. try to replace that sabay narin.
Thread was made nung 2018 pa po sir.
