Results 1 to 8 of 8
    Madali lang iyan, just prepare a used yellow folder in case you damage the gasket. Just trace the shape and cut. Gasket maker or sealant is also ok if you have leftovers. I dont suggest you buy a tube dahil baka tumigas lang. sayang. Sana umaga mo gawin para malamig ang makina.
    though it's easy to to check the thermostat condition with a boiling water, better yeat, palitan nalang, kasi mura lang ang mga thermostat.
    some thermostat do open later even with same specs. I put used same specs thermos on a boling water all at once, and they have different opening time speed.
    Nov 2006
    did you check your rad cap? it's also possible that your t-stat is not opening all the way... how's your water pump?
stuck thermostat?
