Madali lang iyan, just prepare a used yellow folder in case you damage the gasket. Just trace the shape and cut. Gasket maker or sealant is also ok if you have leftovers. I dont suggest you buy a tube dahil baka tumigas lang. sayang. Sana umaga mo gawin para malamig ang makina.
though it's easy to to check the thermostat condition with a boiling water, better yeat, palitan nalang, kasi mura lang ang mga thermostat.
some thermostat do open later even with same specs. I put used same specs thermos on a boling water all at once, and they have different opening time speed.
