Results 1 to 8 of 8
- Aug 2003
- 9,720
June 24th, 2007 11:44 AM #1peeps, patanong naman. weeks after replacing my aux fan, pansin ko that the temp went up and beyond the 3/4ths mark, even only after about 10-15 minutes of driving with the aircon on. with the aircon off, the temperature immediately drops to below the halfway mark; even after an hour of driving with some stop-go traffic, temperature seems to be stable.
some other facts:
-- aux fan seems strong, and engages quite consistently;
-- just replaced the radiator with fresh water/coolant mix;
-- there doesn't seem to be any water/coolant loss, even after extended driving, and multiple incidences of reaching above and beyond the 3/4ths mark.
i'm starting to suspect that it's the thermostat.
Waddya think?
June 24th, 2007 12:38 PM #2
I concur...
but maybe the aux fan rotation is baliktad. wrong polarity.
o baka may unnoticed na harang sa hagin o hard to reach airflow sa bagong installation...
or the new blades has bigger non-airflow center.Last edited by rion; June 24th, 2007 at 12:45 PM.
June 24th, 2007 12:49 PM #3
if your suspect is the thermostat, tanggalin mo yung thermostat tapos ilubog mo sa mainit na tubig, you should hear a click, kapag narinig mo yung click then bumubukas pa sya, kung wala then stuck-up thermostat nga
- Aug 2003
- 9,720
June 24th, 2007 01:51 PM #4is thermostat removal something that a novice mechanic should be doing? baka kasi di ko na maibalik ng maayos e B)
Tsikot Member Rank 5
- Nov 2003
- 3,848
June 24th, 2007 02:36 PM #5it's not too hard to do. just make sure there are no leaks once you have reinstalled it.
June 24th, 2007 02:44 PM #6
Madali lang iyan, just prepare a used yellow folder in case you damage the gasket. Just trace the shape and cut. Gasket maker or sealant is also ok if you have leftovers. I dont suggest you buy a tube dahil baka tumigas lang. sayang. Sana umaga mo gawin para malamig ang makina.
June 25th, 2007 07:41 AM #7
though it's easy to to check the thermostat condition with a boiling water, better yeat, palitan nalang, kasi mura lang ang mga thermostat.
some thermostat do open later even with same specs. I put used same specs thermos on a boling water all at once, and they have different opening time speed.
June 26th, 2007 02:21 AM #8
did you check your rad cap? it's also possible that your t-stat is not opening all the way... how's your water pump?
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
