Results 1 to 6 of 6
    Hi guys,
    Anybody of you knows a shop who can removed the key to my ignition? I have a 2002 Bighorn and I have been searching the forums for ways to solve my problem. So far, all the suggestions didn't work so I am planning to bring it to a shop as a last resort.
    Do you know any shops that specifically handle this particular scenario? By the way, I am from Paranaque.
    Feb 2009
    Quote Originally Posted by stolen*soul View Post
    Hi guys,
    you might already have tried because you said so. but try this again: spray wd 40 or similar spray lubricant into the keyhole, grasp the steering wheel and gently turn either direction alternately while attempting to turn the ignition.
    if your situation is that the ignition turns but the key fails to eject, spray wd 40 and attempt to loosen it from being stuck. good luck or take it to your favorite locksmith
    ganyan din ang nangyari sa patrol ng dating office ko. ginamitan ng spare key (duplicate kung saan saan lang) para sa ignition. Di na mahugot yung susi tuloy.
    Damage: 5K sa nissan casa.
    Jul 2003
    What do you mean by "stuck". just plain stucked and not broken? Does your bighorn have an automatic transmission?
    Quote Originally Posted by tip_tipid View Post
    Yes Sir... It's plain stuck (walang sira) at I am still able to use it to start the engine. Automatic tranny ung bighorn sir.
    Jul 2003
    some car models are equipped with ignition key lock. you will not be able to pull it out unless it is in
    Park Mode. But sometimes even when placed in Park Mode, the mechanism to release the key fails or
    is broken.
Stuck Key on Ignition
