Results 1 to 6 of 6
- Sep 2007
- 56
October 11th, 2011 01:33 PM #1Hi guys,
Anybody of you knows a shop who can removed the key to my ignition? I have a 2002 Bighorn and I have been searching the forums for ways to solve my problem. So far, all the suggestions didn't work so I am planning to bring it to a shop as a last resort.
Do you know any shops that specifically handle this particular scenario? By the way, I am from Paranaque.
October 12th, 2011 02:33 PM #2
you might already have tried because you said so. but try this again: spray wd 40 or similar spray lubricant into the keyhole, grasp the steering wheel and gently turn either direction alternately while attempting to turn the ignition.
if your situation is that the ignition turns but the key fails to eject, spray wd 40 and attempt to loosen it from being stuck. good luck or take it to your favorite locksmith
October 12th, 2011 02:43 PM #3
ganyan din ang nangyari sa patrol ng dating office ko. ginamitan ng spare key (duplicate kung saan saan lang) para sa ignition. Di na mahugot yung susi tuloy.
Damage: 5K sa nissan casa.
- Jul 2003
- 573
October 13th, 2011 12:44 PM #4What do you mean by "stuck". just plain stucked and not broken? Does your bighorn have an automatic transmission?
- Sep 2007
- 56
October 13th, 2011 11:55 PM #5
- Jul 2003
- 573
October 14th, 2011 12:23 AM #6some car models are equipped with ignition key lock. you will not be able to pull it out unless it is in
Park Mode. But sometimes even when placed in Park Mode, the mechanism to release the key fails or
is broken.
You just unregister the device where its currently installed.
National ID Law
