Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jul 2006
    Good day to all tsikoteers!
    I'd like to ask if there is a possibility that i'll manage to save gas by having my car's ECU reprogrammed similar to be the Optra gas consumption.
    My car is old but is still in good condition, its a 94 toyota corolla GLi with 4A-FE engine, but recently, i've come to notice that my gas consumption is way too much for me.
    I've also come to notice that the consumption changed from july this year.
    Spark plugs, change oil, timing belts even engine oil treatments, ive done last month but nonetheless, the consumption didn't change.
    Is there a need to check the engine? Do I need overhaul?
    Thanks.
    Nov 2003
    corollas can't be flashd like the optra.
    have the engine checked kung bakit malakas sya.
    Jun 2006
    Aside from the Optra, is there any other car model whose ECU can be flashed to improve FC?
    Nov 2006
    Quote Originally Posted by erickdpogi View Post
    Thanks.
    94 corolla 4a-fe engine and in good condition,that means well maintain and it running smooth,,before you do the engine overhaul check first the tire pressure then the 4 way alignment,align it if kailangan,...and after that,have somebody to check the ignition timing,because incorrect ignition timing can cause a poor fuel economy and only that,poor fuel economy can be cause by a wide range of problem and some of these include rich air-fuel mixture,engine miss,or leakeage in the fuel system,but like i said check first the ignition timing.
    Jul 2006
    Check the obvious first - tire pressures, excess load in trunk, driving habit, use of AC, etc.
    Jul 2006
    * mbeige, the tire pressures are checked everytime it is used. driving habit, normal; load in trunk is minimal; use of AC always in the center for both the thermostat and fan.
    Recently, even though it's newly changed oil, white smoke is coming out of the exhaust when started. why is this so?
    am using Bosch Super4 sparkplugs and shell helix semi-synthetic as oil.
    Thanks for the replies!
    Aug 2006
    Pre,,,
    ilang Kms/liter ba consumption mo...?
    Jul 2006
    My rough estimate is 500php back and forth from alabang (filinvest) then going to makati cbd and back to alabang. almost empty tank. That is taking the slex at 80-90 kmh at 5th gear. while inside the city, most probably 40-60 kmh only while shifting at 2800-3000 rpm w/c is recommended for economic driving. Also, my car is manual. A/C is turned off during the test, so most probably itll go lower than expected.
    am still puzzled.
    Yung white smoke ba tuwing umaga lang to? AFAIK normal ata un because of the moisture na naipon overnight. Pero after a few minutes dapat mawala din.
    Try shifting at or before 2K rpm. Eto ata mas economical. Of course, taking into consideration yung daan (kung paahon or what).
    Jul 2006
    I dont know if it's on early morning startups only, but when i go on reverse, white smoke is noticeable.
    what do you think is the prob.
    lakas ng gas consumption 500 a day plus tolgate 55.00, baka dahil a/t siya and hindi manual.
    sa friend ko 93 gli din city nya is 7-8km/L, hway niya nag 10km/L daw
    1++,+++km na reading niya.
    ako kasi manda alabang munwalk laspinas then manda 200 a day lang siyempre diesel kasi yon via southexpressway daan ko kasama na trapk
    pero sayo laki ng consumo
    Sep 2006
    piston rings..
    Aug 2004
    RE: judging fuel consumption: Instead of judging by how far you go on the money, find out exactly how many kilometers you can go for the amount of gas you're using.
    500 php? What gas? Unleaded? Premium Unleaded? or boutique (V-Power, Blaze) Unleaded? What price? With lower grades of unleaded, that's 13.5+ liters, with higher grades, 12.5.
    If it's 13 liters, alabang to makati and back is roughly 50 kms. "Almost" empty could mean you're using anywhere from 8-10 liters. Roughly 5-6 km/l? Better make sure.
    But considering part of that is on the highway, there's definitely something wrong.
    Pull the Bosch sparkplugs and check their condition. If they're a few months old, they should be reddish in color. Have a shop check your compression and check for leaks. Like m_ron suggested, you could be leaking oil through your piston rings, or oil and/or coolant into the combustion chamber through a busted gasket.
    If the car doesn't feel like it's losing power, then the problem might be minor... but if it really is a leaking gasket, don't wait too long before having it fixed...
    Quote Originally Posted by userfriendly View Post
    According to rumor on the PTP boards, the JDM/Mazdaspeed ECU for the 323/Familia (96+) has a better timing/fuel map, resulting in more power and better fuel consumption. It's an ECU swap, though, not a re-program... and suwertihan nalang makahanap.
    Jul 2006
    Give us a definite figure of your MPG, tire pressures and current mileage. Mahirap ang tantsahan, even if you check them everyday.
    If you're concerned of white smoke at start up, it may just be condensation as water in the exhaust is being burned. If the white smoke persists when driving with a warmed up engine, you better start checking for headgasket problems.
    For the 4AFE engine, blue smoke at start up and when driving is usually indicative of valve stem seals.
    Jul 2006
    Merry Xmas to everyone!
    Thanks for replies, going to the prob, my uncle who's a mechanic helped me assess the prob, since there were no indications of leaks outside, when he checked the engine, he told me, the engine need Top Overhaul.
    How much is that for an engine? prices for b/new parts like valve seals, piston rings and stuff? also, there is an indication that there are misfires of the sparkplugs or rather there is oil on the places where the plugs are placed.
    Anyone knows a quote on the prices? thank you very much for the replies again!
    Jul 2006
    Merry Xmas to everyone and thanks for those replies!
    Anyway, going back to the problem of my car, an uncle of mine dropped in to help me assess the problem, although there were no signs of external leaks, he told me that the engine need Top Overhaul, it may be so for these cases:
    1. slot 2 and 4 for the spark plugs (from the right) have oil leaks. It was also checked if the wires leading to the plugs have currents, they do.
    2. the engine oil depletes rapidly (since changed oil a few months ago), and mixtures of water and oil were found at the exhaust.
    3. later, at the lower part of the exhaust manifold w/c is attached to the engine , there was a bit of oil buildup at the right bottom side.
    4. He also noticed that the torque-y feeling when you go up was missing now.
    5. He even told me that there might be some loss of pressure inside (i dunno what that was).
    He recommended to me to go Top Overhaul and have it fixed asap. He just came back from the states so we don't know how much that would cost.
    Estimates? cost? anyone know a shop that is reliable, trustworthy and is considerate on the prices of the parts?
    a friend of mine told me that it would cost around 10-20k depending on the condition.
    How much are the parts? anybody knows where i can get good parts? ^_^
    Thanks again for the replies and happy holidays!
    Sep 2006
    you don't need top overhaul,have your piston and piston rings checked.check appropriate clearance.
    Aug 2004
    If there's oil on the sparkplugs, then there might be something there.
    10-20k sounds about right. Just cross your fingers that you don't need your cylinder head re-faced.
    Nov 2003
    looks like you have to crack open the engine na nga to see what the problem is.
  20. #20
    My suggestion is to remove the cylinder head then check the head gasket as to where the oil was coming from. Was seeping through the gasket area? Through the valve guides/seals? Or through the cylinder walls (busted piston ring/bore)?
    You should have your answers then.
    HTH!
Gas consumption too much for my corolla
