Results 11 to 20 of 23
    whats your ride CoolGal?
    mazda323 po
    Dec 2002
    Nasa Php 200 up price ng speedo cable at available yan sa suki niyong auto supply. Di naman maselan trabaho yan, pakabit ako dati charge ng labor e Php 150 lang, less than an hours work. 8)
    SALAMAT PO SA REPLY.
    Try to lube it first. Baka malagkit na yung loob kaya di na free moving yung cable.
    To DIY, remove the socket connecting the cable to the panel tapos apply at least 10 drops of oil (can be motor oil) to the cable itself and let it drip into the cable. Reattach the cable to the panel after the oil has sip through.
    Hope this helps.
    Quote Originally Posted by GoThicbLuE
    OT-
    Habang nasa speedometer topic tayo, question ko lang yung speedo ko medyo mali yata ang reading kasi I feel mababa ang reading nya at hindi muna gagalaw hanggang mga 20kph na takbo. i compared the felt speed from my other car kasi. ano kaya problema?
    Tulong naman people....
    Up ko lang poi.... wala pa bang reply??
    2types daw yun cable... may mahaba and maikli. pinatanggal ko yung speedo cable ko to check, putol na sya talaga. yung naputol yung maikli and i asked sa banawe it costs 500-800. *******! ang mahal pala nun... ganon ba talaga price nun? akala ko it costs around 200 lang. yung mahabang cable mas mura ng konti.
    napalitan na speedo cable ko. 400 kuha ko. meron kse auto supply tito ko tapos nagpahanap ako sa kanya, replacement nga lang. 70 lang labor... hehehe pede pala DIY yun. pero OK lang pa xmas ko na lang sa mekaniko ko. :D
    In most cases kapag ang speedometer needle niyo po ay fluctuating in lower speeds.
    Ay kailangan na pong palitan ng bagong cable yan due to "Cable Stretching"
    RIDE ON...
    8)
    Up ko lang po itong topic. My ride is a Mitsu L200. Medyo eratic na rin ang speedo cable ko sa low speed. Talaga bang P800.00 ung new one? mahal naman,,, :cry:
speedometer needle
