Results 11 to 20 of 23
- 152
- Dec 2002
- 21
December 12th, 2002 01:48 PM #13Nasa Php 200 up price ng speedo cable at available yan sa suki niyong auto supply. Di naman maselan trabaho yan, pakabit ako dati charge ng labor e Php 150 lang, less than an hours work. 8)
- 152
December 12th, 2002 03:01 PM #15
Try to lube it first. Baka malagkit na yung loob kaya di na free moving yung cable.
To DIY, remove the socket connecting the cable to the panel tapos apply at least 10 drops of oil (can be motor oil) to the cable itself and let it drip into the cable. Reattach the cable to the panel after the oil has sip through.
Hope this helps.
December 18th, 2002 10:52 AM #16Originally Posted by GoThicbLuE
- 152
December 18th, 2002 11:58 AM #172types daw yun cable... may mahaba and maikli. pinatanggal ko yung speedo cable ko to check, putol na sya talaga. yung naputol yung maikli and i asked sa banawe it costs 500-800. *******! ang mahal pala nun... ganon ba talaga price nun? akala ko it costs around 200 lang. yung mahabang cable mas mura ng konti.
- 152
December 19th, 2002 11:16 AM #18napalitan na speedo cable ko. 400 kuha ko. meron kse auto supply tito ko tapos nagpahanap ako sa kanya, replacement nga lang. 70 lang labor... hehehe pede pala DIY yun. pero OK lang pa xmas ko na lang sa mekaniko ko. :D
- Nov 2002
- 70
December 27th, 2002 12:02 AM #19In most cases kapag ang speedometer needle niyo po ay fluctuating in lower speeds.
Ay kailangan na pong palitan ng bagong cable yan due to "Cable Stretching"
RIDE ON...
8)
March 19th, 2003 09:26 PM #20
Up ko lang po itong topic. My ride is a Mitsu L200. Medyo eratic na rin ang speedo cable ko sa low speed. Talaga bang P800.00 ung new one? mahal naman,,, :cry:
