Results 1 to 10 of 25
- Nov 2005
- 26
November 15th, 2005 03:05 AM #1i have a corolla XL 2002. ang problem niya is there are times na during sa pag-release ng clutch at first gear, nanginginig. it's not the usual nginig na kulang sa tapak sa gas. in fact, pag-tinapakan ang gas, it shudders violently. a friend of mine with a corolla GLi naman, ganun din. the problem is intermittent. pag sinusumpong, ang hirap timplahin ng clutch- sobra ang nginig. any idea what causes this?
November 15th, 2005 07:05 AM #2
hmmm...engine support? nagpalit k n? pero bago pa kasi yung oto mo eh...
- Nov 2005
- 26
November 15th, 2005 01:14 PM #4Originally Posted by umzzzzz
- Nov 2005
- 26
November 15th, 2005 01:15 PM #5Originally Posted by StraightSix
November 15th, 2005 05:33 PM #6Originally Posted by psycho
Kung yan nga problema, afaik palit ng clutch ang solusyon diyan, or (not really recommended) sunog ng konti sa clutch.
jagxtrm GuestNovember 15th, 2005 09:32 PM #7
baka sira na ang pressure plate ...
lagi bang overloaded yng corolla mo (4 or 5 passengers or equivalent baggage load) ??
try this to test ur pressure plate...
- park ur car (with at least 5 meters distance sa harap)
- secure the hand brake (yng highest na kaya mo)
- start the engine & lagay mo sa 5th gear
- slowly release the clutch and your right foor naman sa gas (para hindi mamatay ang engine). keep the rpm between 1,000 to 1,500. do this only for a maximum of 30 secs!
kng nag shake kagaya ng sinabi mo -- pressure plate yan
kng parang umakyat naman yng rpm kahit halos released ka na sa clutch -- may clutch slippage ka na, it is time to replace ur clutch
November 15th, 2005 09:43 PM #8
nabaha ka ba or something? i've got the same problem before. nagpalit kami ng clutch, pressure plate, saka pilot bearing.
Toyota is my choice
- Aug 2005
- 2,063
November 16th, 2005 07:41 AM #9Originally Posted by jagxtrm
jagxtrm GuestNovember 16th, 2005 11:40 AM #10Originally Posted by finchy18
wag mo lng gawing 'frequent' yng testing, or else u will do more damage sa clutch mo.
pwede rin naman gawin yang test na yan pag paakyat ka ng flyover. pag nasa 20-30 degree incline ka na, mag full stop ka tapos try mo i-release yng clutch habang nasa 1,000 to 1,500 rpm lng yng engine mo, cyempre wag mo na i-engage yng handbrake.
of course, wag mo gagawin yang flyover test pag ma-traffic, bka puro ingay ng busina marinig mo ...
o kaya marinig mo naman yng famous "Filipino Greeting" galing sa ibang drivers ... hehehe
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
