Results 1 to 10 of 21
April 13th, 2004 12:23 AM #1
Question lang po: san kaya puwede magpa-palit ng timing belt outside of casa? Yung mura tsaka 1 day lang pero ok ang gawa...
Corolla GLI 98 ang sasakyan.
Salamat!
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 13th, 2004 09:14 AM #3
Yep, tatawag ako kasi may nagrecommend na sa speedyfix na ok daw gumawa! Tnx man!
April 13th, 2004 02:57 PM #5
kapag timing belt po ba,
kailangan ba original ang bibilin? or may magandang brand (replacement) na timing belt?
thank you.
April 13th, 2004 11:19 PM #6
for me, i think i'll buy the original timing belt kahit mahal.. mahal overhaul ng engine pag napatid timing belt..
April 13th, 2004 11:42 PM #7
Aside from timing belt, meron pang papalitan na "something" bearing. May nakakaalam ba dito kung ano yon?
Anyway tatawag naman ako ulit. Check ko muna how much ang gastos sa parts...
April 14th, 2004 10:24 PM #8
Tensioner bearing po iyon, but not all vehicles have it, some have idler pulleys. And some engines have both.
Meron pa isang kasabay yan pinapalitan, water pump. Meron din kasing engines na kasama ang water pump pulley sa timing belt.
- Nov 2003
- 3,849
April 16th, 2004 07:22 AM #9i've had no problem with the replacement timing belts we often use. normally matibay din mga ito.
April 16th, 2004 08:59 AM #10
Eto ang sabi sa casa for 4A-FE:
timing belt 1,443
tensioner 3,722
Yun lang daw ang pinapalitan.
Labor kay speedyfix: 1,500.
Discount naman diyan sir, hehehe.
Meron pa akong 200kms to go before 100Tkm. Which means I have 200kms to decide engine swap or just retain the stock for a while more. :-)
Monk-owned R53
