Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jan 2004
    Question lang po: san kaya puwede magpa-palit ng timing belt outside of casa? Yung mura tsaka 1 day lang pero ok ang gawa...
    Corolla GLI 98 ang sasakyan.
    Salamat!
    Nov 2003
    tawag ka sa shop for a quotation if you like
    7237625
    Jan 2004
    Yep, tatawag ako kasi may nagrecommend na sa speedyfix na ok daw gumawa! Tnx man!
    Some other gas service stations also do it for a fee.
    kapag timing belt po ba,
    kailangan ba original ang bibilin? or may magandang brand (replacement) na timing belt?
    thank you.
    for me, i think i'll buy the original timing belt kahit mahal.. mahal overhaul ng engine pag napatid timing belt..
    Jan 2004
    Aside from timing belt, meron pang papalitan na "something" bearing. May nakakaalam ba dito kung ano yon?
    Anyway tatawag naman ako ulit. Check ko muna how much ang gastos sa parts...
    Tensioner bearing po iyon, but not all vehicles have it, some have idler pulleys. And some engines have both.
    Meron pa isang kasabay yan pinapalitan, water pump. Meron din kasing engines na kasama ang water pump pulley sa timing belt.
    Nov 2003
    i've had no problem with the replacement timing belts we often use. normally matibay din mga ito.
    Jan 2004
    Eto ang sabi sa casa for 4A-FE:
    timing belt 1,443
    tensioner 3,722
    Yun lang daw ang pinapalitan.
    Labor kay speedyfix: 1,500.
    Discount naman diyan sir, hehehe.
    Meron pa akong 200kms to go before 100Tkm. Which means I have 200kms to decide engine swap or just retain the stock for a while more. :-)
    Jan 2004
    Ok na. Napalitan na ng tensioner at timing belt. My engine has a new lease on life. Di na pinaltan water pump kasi ok pa daw sabi ni Felix ng Speedyfix. Ok nga dun!
    Salamat sa mga sumagot. Sa uulitin!
    Apr 2004
    peeps,
    tanong lang, magkano labor sa honda casa pag nagpalit ng timing be;t at bearing? at water pump:confused:
    timing belt 1,443
    tensioner 3,722
    Mahal din pala labor ng Timing Belt re placement... Buti nalang na pirate ko yung Mechanic sa casa... then sa bahay nya nalang ginawa wala pang 2hrs tapos 1000 lang binayad ko tapos pina inom ko lang.. ayon ang dali ng tawagin pag may papaayos ko hehehehe.. trabahong casa na mura pa labor
    Nov 2003
    no problem pare!
    thanks din
    Nov 2003
    Usually po ba, when is the right time to change the timing belt?
    Jan 2004
    Sabi nun casa 100TKm for 4A-FE. Nakuha ko yung tinanggal sa akin at 99934km mukha namang ok pa. Depende din sa gamit at sa kotse, kung ano sabi sa manual...
    Most car manuals advise 100,000kms. on timing belt change. Some manufacturers even advise 120,000kms. To be safe, I've seen numerous vehicles change their timing belts at 80,000kms.
    Nov 2003
    hondas normally require the change at 70,000 kms. it's cheaper than having a top overhaul due to a broken belt
    Apr 2003
    aside from timing belt and tensioner bearing, don't you have to replace the camshaft and crankshaft seals? ganyan yung ginawa sa lancer namin dati.
    ano pa ba yung usual na sinasabay palitan?
    yup, yan din ang ginagawa ko para isang bukasan lang.
Replace timing belt
