Results 1 to 10 of 10
- Nov 2004
- 115
May 24th, 2005 01:45 PM #1hi there,
medyo mataas na kasi ung handbreak ko.. pano ba adjust ito?
pajero 2500 diesel
thanks.
- Jun 2004
- 476
May 24th, 2005 05:57 PM #2Lifted from the workshop manual for a Gen 1 Pajero.
PARKING BRAKE LEVER STROKE CHECK AND ADJUSTMENT
1. Pull the parking brake lever (hand brake) with a force of approximately 45 lbs and count the number of clicks. Standard value = 4-6 clicks
2. If the parking brake lever stroke is not within standard value range, make the adjustments by following the procedures below:
- Loosen the adjuster to slacken the parking brake cable
- Tighten the adjuster slightly, repeating pulling and releasing the parking brake lever, to adjust the brake shoe clearance
- Tighten the adjuster until the parking brake lever is within standard value
- After adjustment ensure that the adjuster is secured with the nut holder
3. Return the parking brake lever, remove the brake drum, and check to ensure that the brake lever adjuster is touching the shoe
- Caution: If the parking brake cable is pulled too far, the adjuster lever does not fit the adjuster, resulting in faulty operation of the brake shoe adjuster
4. With the parking brake lever in released position, turn the rear wheel to confirm that the rear brakes are not dragging
- Nov 2004
- 115
May 25th, 2005 12:46 PM #3hey paj4x4, thank you very much for the info.
where should i find the adjuster? is that somewhere near the tires? or is just within the handbreak lever?
thanks!
May 25th, 2005 12:55 PM #4
Nasa ilalim merong adjuster. Right where the cable splits into the left and right cables.
- Nov 2004
- 115
May 26th, 2005 01:43 PM #5Originally Posted by OTEP
May 26th, 2005 11:26 PM #6
Humiga ka sa ilalim ng Pajero. Trace mo where the handbrake cable exits the vehicle cabin to go to the rear wheels. At the point, where they split, andun may adjuster din.
- Nov 2004
- 115
October 19th, 2016 07:47 AM #9
any idea magkano labor nito pag pinagawa sa labas? para alam ko kung fair price yun singilin sakin
car is compact lang (vios)
salamat
October 19th, 2016 09:33 AM #10
ahm... and may i suggest if its possible.... to correct one of the words in the title from "handbreak" to "handbrake"... sorry can't help myself...
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
