Results 1 to 15 of 15
    Sep 2016
    Good Day!
    Ayaw mag start ng oto ko this morning, wala din any indicator sa dashboard, usually pag ka "on" meron na. Then I asked yung taga talyer battery daw, kinargahan nya for 3 hours tapos try ko nag start na yung oto.
    Question:
    Do I need to replace the battery? I think it's just only 6months from the date I purchased.
    or
    Ok pa yung battery, sincen nag start na mag kaka power naba ulit yung battery?
    Salamt po sa mga sasagot.
    Have the battery checked. It should still be under warranty. If defective, have it replaced free of charge.
    ➰Shine the light➰
    How old is the battery? It could be defective, or worse, you have a problem in your electrical wiring.
    Jan 2009
    New batteries failing in just 6 months is very rare. I'll put my money on either something (like an accessory or any sources of battery drain) was left running overnight or the charging system isn't doing its job.
    Battery dealers have a way to test if your charging system is working.
    Sep 2016
    I think 6months. Yes the other mechanic told us to monitor if the problem still occurs its better to check the electrical wiring. Any signs na may problem ang electrical wiring? Weird lang kasi last week napansin ko na meron unusual na sound pag inoopen ko yung aircon its like a "tik tik" sound, pero pag naka off naman walang sound.
    Sep 2016
    ➰Shine the light➰
    Thank you Sir!
    Jul 2006
    Before anything else, question: What car? Year model?
    Sep 2016
    Vios 1.3J 2011
    Thank you
    Jul 2006
    It may be your battery. Though as a precaution, have your charging system checked.
    For comparison, I have a 2010 Vios E AT at home. To date, naka 3 batteries na ako (from new). The charging system is still okay.
Dead Battery
