Results 11 to 20 of 32
November 16th, 2005 11:50 PM #11
hello again....
sorry kng makulit ako...pnapakiramdaman ko pa ksi yng tsikot ko eh...i have some additional questions...
how would you know pag kelangan na tlga ng overhaul?
sa ngayon ksi, pag nag-aaccelerate ako ng dahan-dahan, pagminsan parang "umuuga" (duno the term) yng pag accelerate..yng hindi super smooth ba...also pag tipong i-try ihataw....as in change gear sa mga 3k-4k rpm then bitaw clutch parang kumakatok sya....what do these symptoms indicate?....sana nmn d overhaul...
TIA!!!
November 17th, 2005 12:17 AM #13
can you please explain what tope is?...also is this the same as "katok"
and mgkano ba overhaul??
Thanks sir!
BANNED BANNED BANNED
- 3,790
November 17th, 2005 05:32 AM #14it's not a carb problem...probably the valve tappet needs adjustment
November 17th, 2005 08:44 AM #15Originally Posted by wildthing
question...ginagawa ba ito kapag ngpa tune-up?...pina tune-up kasi yng ktse kahapon pero d ako nagdala...
FYI, i am asking these questions kasi nraramdaman ko pag nag-accelerate ako d smooth...around 20-40kph parang "umuuga" (maling term ata) or parang may konting pigil sa pgka accelerate....
and then also, pag i-try ihataw, i.e. from 1st gear, accelerate then change pagka around 3-4k change gear sby bitaw clutch...may konting katok or tope...whichever it is...
i'm not usre kung tune-up lang ba...kng air filter cleaning...kng change gasoilne ba para mawala....
icp ko rin bka gasoline ang cause, ksi nung bagong kuha ko ito from the prev owner, parang la nmn ako nraramdaman, or dko lang msydo npansin..not sure....ten one time, kinargahan ko ng unleaded ksi yun nmn daw knkrga ng prev owner...after nun nramdaman ko parang mdyo pigil yng accelerate pero d msydo...tpos nung ngpagas ako uli, XCS kinarga ko (d ako nag drain)...then after that, observ ko is parang lumala pa ata...
d kya naapektuhan ang engine because of this? or tuneup and d proper fuel will fix this na?
TIA!!!
- Sep 2005
- 188
November 17th, 2005 11:04 AM #16Ung car ko dati XCS nilalagay ko then one day habang nasa flyover traffic biglang nabulunan engine tapos namatay. Nirev ko na lang ng nirev hanggang maka-uwi ako. Ginawa ng mechanic ko, chinoke ng chinoke kasi marami na daw "gum" ung loob ng carb galing sa fuel na gamit ko. Suggest nya palit ako sa higher octane. Now im using BLAZE kaya lang mas mahal
- Sep 2005
- 103
November 17th, 2005 02:15 PM #18Kung tumo tope ang engine mo malamang u need to have ur valve tappet adjusted as wildthing just posted... or i suggest u change ur fuel to a higher octane rating.
November 17th, 2005 06:36 PM #19Originally Posted by sirkosero
avoid A&M. kung anu-ano sasabihin sa yong papalitan pero di naman pinapakita sa yo yung ginagawa sa carb nyo. amp!
SiRaNeko
- Jan 2003
- 973
November 17th, 2005 08:56 PM #20san po banda sa kamuning? left o right side coming from edsa?
also kung me contact number po?
Thnx
ganda sana, if we can exchange discharged batteries for fully charged ones, the same way we...
All New Toyota Corolla Cross
