Results 1 to 20 of 32
    Sep 2004
    hello...i just have some questions regarding this...
    may masamang effect ba ito, i mean kapag d "perfect: ang pagpapagawa nito mas makakasama pa ba sa engine?
    also, how much kaya ito and any recommended shops for this?
    thanks peeps!
    yes nakakasama ito instead of nakakabuti kung hindi maganda at tama ang pagkakabalik...but the chance of a faulty repair is lower kung professional ang tatrabaho.
    Sa DIY matututo ka pero it would NOT be quick, easy and cheap. I learned it that way so I would not necessarily tell you to open it up and DIY it unless you are willing to LEARN and SPEND some money and time on it.
    Before having it overhauled, I usually recommend flushing it out with a carburator cleaner which you can buy sa ACE hardware or even sa auto supply stores. Cost about P150-350 yung isang canister. You can end-up using it all up kung madumi na carb mo. It spray it until it becomes very clean (sa outside ng carb). As for the inside ng carburator, it would be best to run the engine muna until normal operating temperature. Spray the insides of the carb while alternately reving (rev hard!!!) it up to suck up the carb cleaner and fine dirts that clogged your carb jets. Spraying the inside of the carb will choke the vechicle that's why you need to rev it up.
    When everything is very clean na, re-position the filter covers again (replace the filters as much a possible to a new one). And spray the linkage pivots and springs with WD40 to oil it a bit (3-in-1 oil is okay rin).
    WARNING: During this process of cleaning you shouldn't adjust anything (mga tornillo to open/close jets for fuel and air) from the carb unless you know what you are doing.
    After that drive your car around and feel the improvement. Kung tama ang gawa mo and wala kang problem sa carb you would have a great riding feel na ulit. Kung meron pa rin problem then I suggest you go to a professional shop na.
    Kamuning street have a lot of carb specialist pero I don't know if this is near to you as well as kung alin dito ang magaling. Labor is about P350-500 and parts needed to be replaced is probably between P300 to P700 (carburator repair kit). Kung magaling ang repair man and your carb is in good shape you might not spend that much sa parts. Jets can cost as cheap as P10/piece and the carb gasket is P20/12 inch square...sobra-sobra na ito sa kailangan.
    Pero kung sira na ang mga internal spring ng "mini pump" ng fuel or the variable pin to adjust the fuel flow then yung kit na ang kailangan mo.
    hope this help.
    Jun 2005
    nagpa-overhaul ako ng carb. based from my experience, if ur gonna have the carb dismantled, gumamit ka na ng repair kit. wag yung pa-brush-brush lang ng kerosene tapos walang pinalitan. pinagawa ko dati yun. lalo pa nasira ang carb ko... pumugak ng pumugak. apparently, nasira pa nung gumawa ang plunger. nung pinagawa ko sa kamuning, sabi sa akin palit plunger lang daw kailangan pero naisip ko na kaya nga may repair kit para pag binuksan at napalitan na ang isang parte, dapat lahat na. kaya gumamit na lang ako ng repair kit. cost me 350 pesos plus 300 sa labor. ayos takbo.
    my main point is, pag magpapabukas ka ng carb, use a repair it and replace yung parts na kasama naman ng repair kit. saves you the hassle in the long run. also, go to a reputable shop. sa kamuning madami
    Apr 2005
    Quote Originally Posted by sirkosero
    bro, san ka sa kamuning nagpa-carb overhaul? tia
    Jun 2005
    Quote Originally Posted by maverick34
    sa m2m ako nagpagawa. suggestion kasi sa akin nung autosupply dun, kung magpapaoverhaul ng carb, dapat dun sa nakikita mong ginagawa carb mo. kasi daw sa iba tulang ng a&m, tinatago ang paggawa ng carb mo at minsan kinakarne ang ayos pang piyesa.
    this is so true. M2M i think is one of the best carb shops in kamuning. sa harapan mo babaklasin ang carb para ipakita sa yo kung ano ang sira.
    avoid A&M. kung anu-ano sasabihin sa yong papalitan pero di naman pinapakita sa yo yung ginagawa sa carb nyo. amp!
    Sep 2004
    thanks for the informative replies guys...well sana d pa kelangan ng overhaul tong akin...ngtanong lng naman ako just in case...
    cheers!
    kung meron air filter ang tsikot mo, makukuha pa yan ng carb cleaner spray para malinis ang carb mo. sabay tune-up na rin para mai-tama ang timing ng engine at tono sa carb setting. magpa carb overhaul ka kapag walang air filter sa carb mo dahil malamang may foreign particles tulad ng sand & dirt na nakapasok sa carb mo.
    Sep 2004
    Quote Originally Posted by zero
    hello...question regarding this...
    itong carb cleaner spray, meron ba ang mga service shops nito or DIY lang ba ito?...mgkano po yng mgagastos sa ganito?
    thanks!
    merun normally but they'll charge you more...a canister ng carb cleaner cost between P120 to 350 normally depende sa brand and size...i usually use the 3M brand
    Jan 2003
    any shops in kamuning that you can recommend?
    Sep 2004
    hello again....
    sorry kng makulit ako...pnapakiramdaman ko pa ksi yng tsikot ko eh...i have some additional questions...
    how would you know pag kelangan na tlga ng overhaul?
    sa ngayon ksi, pag nag-aaccelerate ako ng dahan-dahan, pagminsan parang "umuuga" (duno the term) yng pag accelerate..yng hindi super smooth ba...also pag tipong i-try ihataw....as in change gear sa mga 3k-4k rpm then bitaw clutch parang kumakatok sya....what do these symptoms indicate?....sana nmn d overhaul...
    TIA!!!
    Jun 2005
    tope
    Sep 2004
    can you please explain what tope is?...also is this the same as "katok"
    and mgkano ba overhaul??
    Thanks sir!
    it's not a carb problem...probably the valve tappet needs adjustment
    Sep 2004
    Quote Originally Posted by wildthing
    thanks for the reply sir...
    question...ginagawa ba ito kapag ngpa tune-up?...pina tune-up kasi yng ktse kahapon pero d ako nagdala...
    FYI, i am asking these questions kasi nraramdaman ko pag nag-accelerate ako d smooth...around 20-40kph parang "umuuga" (maling term ata) or parang may konting pigil sa pgka accelerate....
    and then also, pag i-try ihataw, i.e. from 1st gear, accelerate then change pagka around 3-4k change gear sby bitaw clutch...may konting katok or tope...whichever it is...
    i'm not usre kung tune-up lang ba...kng air filter cleaning...kng change gasoilne ba para mawala....
    icp ko rin bka gasoline ang cause, ksi nung bagong kuha ko ito from the prev owner, parang la nmn ako nraramdaman, or dko lang msydo npansin..not sure....ten one time, kinargahan ko ng unleaded ksi yun nmn daw knkrga ng prev owner...after nun nramdaman ko parang mdyo pigil yng accelerate pero d msydo...tpos nung ngpagas ako uli, XCS kinarga ko (d ako nag drain)...then after that, observ ko is parang lumala pa ata...
    d kya naapektuhan ang engine because of this? or tuneup and d proper fuel will fix this na?
    TIA!!!
    Jun 2005
    when u say "umuuga" ano meaning mo? yung tipo ba na pag-apak mo sa pedal eh parang nagaalangan yung engine bago humataw (hesitation)?
    kung ganun nga ang nangyayari, it is caused by a vacuum leak. may sira ang carb ang has to be repaired. as for my case, plunger ang sira.
    as for katok, u can either change to higher octane gas or have ur timing retarded para hindi tomope. not sure kung valve tappet adjustment ang makakatanggal ng tope pero im quite sure na sa timing aayos yan. (based on experience). yung valve tappets, kapag kailangan ng adjustment, maririnig mo kasi maingay yung engine. mas maingay than usual kahit naka-idle lang.
    Quote Originally Posted by aann
    TIA!!!
    Sep 2004
    yes parang ganito nga..kaso konti lang and mostly this happens pag mabagal, around 10-40kph....pano ko ipapa-check if may sira nga ang carb?..kelangan bang buksan ito para makita?...delicate na ba yng bubuksan lang ang carb to check?
    thanks for replying!
    Sep 2005
    Ung car ko dati XCS nilalagay ko then one day habang nasa flyover traffic biglang nabulunan engine tapos namatay. Nirev ko na lang ng nirev hanggang maka-uwi ako. Ginawa ng mechanic ko, chinoke ng chinoke kasi marami na daw "gum" ung loob ng carb galing sa fuel na gamit ko. Suggest nya palit ako sa higher octane. Now im using BLAZE kaya lang mas mahal
    Sep 2004
    ngyn ok na yng ktse mo?
    what's this choke?...is that expensive?
questions on carb overhaul
