Results 11 to 19 of 19
- 54,258
September 3rd, 2016 08:53 AM #12in the olden days, an oil warning light when the engine is running, means one of two things:
1. not enough oil in the sump; and
2. the engine is tired and will need a general overhaul soon. lalo na kung flickering.
another cause, although, in our experience, uncommon, is a mis-behaving oil sending unit.
- 54,258
September 3rd, 2016 08:56 AM #13
- 54,258
September 4th, 2016 12:02 AM #15Originally Posted by ;2762002
- Sep 2016
- 5
September 18th, 2016 07:22 PM #16How old is the car? Old car and the lack of managed oil changes every 5000 km can result in worn engine bearings.... Worn bearings and hot engines only allow more oil to escape between the crankshaft rod ends and the crankshaft journals which will result in time an illumination of the engine oil light.
- Jun 2005
- 3,774
September 18th, 2016 10:51 PM #172010 pa yung original post. Ano na nga ba nangyari kay TS. Di ko na din sya napapansin sa forum ah
- Aug 2014
- 73
September 25th, 2016 05:25 AM #18Yung akin 2001 isuzu crosswind xto parehong pareho kami ng case nung unang unang nag post. Pag naka idle umiilaw yung akin habang nakababad sa D pero pag neutral or paaandarin ko nawawala sya. Yung pag ilaw nya is dim lang na makurap. Ginawa ko pinalitan ko yung oil sending unit. Pero dahil di pa ko natrapik ng matagal simula ng pinaayos ko last month di ko pa nasubukan kung iilaw pa o hindi. Nagulat lang ako sa nabasa ko dito mismo sa thread na to na baka daw tired na yung engine natakot ako. Pero naibabyahe pa namin ng malayo at wala naman akong na eencounter na problema. Siguro iol sending lang. Minsan susubukan ko mag idle ng baka drive yung kambyo. Pero sa palagay ko ok na yung akin kasi minsan matagal na din ako naka hinto ng nakadrive di na man na umiilaw.
- Nov 2016
- 13
byd seal5 dmi. that coolant tank is the same setup like in the fords. plastic coolant lines :twak2:...
BYD Philippines
