Results 21 to 30 of 99
Tsikot Member Rank 3
- Dec 2002
- 551
June 23rd, 2005 05:53 PM #21Originally Posted by Field Master
sir like hard starting and white smoke ?
June 23rd, 2005 06:46 PM #22
Johnart, I can start my rig in 1 click in cold morning. However, the body shake is very unusual at very low and erratic rpm. Just like you I have to step the accelarator for a moment until the rpm stabilized. I have noticed this for the last two weeks. I'm ruling out glow plugs or electrical stuff as I could bring to life the engine in one click. My battery is just 2 months old. Last time I replaced my fuel filter is 9mos ago and in that period I haven't bleed the filter (excpet of course when it was installed).
So can somebody post procedure on how to bleed the fuel filter
June 23rd, 2005 08:41 PM #24
hard starting sa umaga ,pwedeng battery
sulit kana sa battery mo 3 yrs na pwede ng palitan ,
or pa check mo muna ang voltage nyan kung ok pa ,sa battery shop,
check heater glow plug ,
check starter (baka kailangan ng cleaning )
check injection pump (sa calibation center kailangan ng tamang idle adjustment or needs to be bleed)
sabay check sa nozzles and fuel filter
check fuel tank (baka me nahalong tubig, needs to be drain and clean)
check fuel lines
compression test
check engine
- Jun 2004
- 476
June 23rd, 2005 11:07 PM #25Johnart,
If there is excessive white smoke, the engine shakes/vibrates a lot, and you cannot control the rpm the problem is with the injection pump. Diesel fuel is getting into your engine. The injection pump's bypass plug is busted.
Pull out your dipstick and smell/feel the oil. If you can smell diesel fuel and/or if the oil is kind of diluted/thin (malabnaw) then this is the culprit.
A friend of mine with a Gen 2.5 experienced this last year. He was on Edsa and suddenly the 4m40 engine went wild - rpm went up to 4k and really excessive white smoke came out of the tail pipe. It was so excessive that vehicles/buses following him stopped or slowed down due to poor visibility.
He immediately turned off the engine and called us up. We went to see the rig with a mechanic. The first thing that the mechanic did was to inspect the dip stick. To our surprise the "oil" level was at the very top part of the dip stick. We thought that Mitsubishi over filled it during the last PMS. Upon closer inspection the "oil" was really diluted and it smelled like diesel fuel.
We had his rig towed to a shop and had it's injection pump checked. The bypass plug (I'm not really sure what the exact part name is) was busted. Diesel fuel was entering his engine! Good thing that diesel fuel is also some sort of lubricant. If it were a gas engine an overhaul would have been needed.
Apparently the incident on Edsa was the third or fourth time he noticed his rig spewing out white smoke and at the same time the engine vibrating/shaking rather excessively. These are early signs.
I suggest you have your rig's injection pump examined right away.
- Dec 2002
- 551
- Dec 2002
- 551
June 23rd, 2005 11:56 PM #27Originally Posted by BlueBimmer
heheh sir thats a good title sarap palitan ang title
- Dec 2002
- 551
- Dec 2002
- 551
June 24th, 2005 12:05 AM #29Originally Posted by paj4x4
Xiaomi E-Car
