Results 1 to 20 of 99
    Dec 2002
    Quote Originally Posted by Field Master
    Hi Johnart, Nice to hear that you are ok now.
    By the way, can you please elaborate on pumping the fuel while the ignition jey is on. How do you do that? How do you pump the fuel? Is that by pressing the accelerator prior starting the car?
    Its not as simple as using the accelerator sir( sanay po kayo sa gasolina noh ? : ) ). Its using the hand pump on top of the fuel filter. Pressing it down and pumping it till it gets really hard to pump. Which mean air has been removed from the fuel system. BTW this procedure is not the complete one. To completely remove the air you have to bleed the fuel line by opening the fuel hose one by one. Which is very messy.
    Apr 2005
    para kang nag bo- bomba ng tubig sa poso,
    pasiritin ang diesel fuel sa mga linya,
    messy talaga,
problem with my pajero
