Quote Originally Posted by johnart View Post
Hi guys, here is the update of the overhaul of my 4m40 engine
Labor :
Pull down engine assembly for major overhauling, replace main bearing, conrod bearing, piston rings, liner assembly, engine valve, valve seal, overhauling gaskets. Assemble and recondition engine assembly P12,000
Machine shop P30,036
Calibration (minor cleaning and changing of injectors) P680
Total for labor P42,716
Parts
1 set engine sleeve P2,160
1 set piston rings P3,400
1 set main bearing .25 P1,950
1 set conrod bearing .25 P950
1 set thrust washer P600
1 set balancer bushing(orig) P1,700
1 set piston pin bushing P650
8pcs engine valves (orig) P7,600
8pcs valve guide (orig) P3,680
1 set overhauling gaskets (orig) P13,200
1 pc aircon belt P320
2 pc alternator belt P700
1 pc oil filter P340
1 pc fuel filter P360
4 pcs nozzle tips P7,040
8 lts motor oil P875
3 lts atf P390
total for parts P45,915
grand total of overhaul P88,631
at the moment the car is having a stationary break-in and a bit adjustments here and there. Having a bit of a problem with the injector. Fuel seems to leak out of it overnight. Hopefully this is all the cost
Sir,
pwede malaman kung saan shop kayo nag pa overhaul ng pajero nyo? and how many days ang inabot b4 matapos?4M40 ba engine ng pajero nyo. Thanks
