Results 1 to 10 of 29
- Aug 2006
- 3
August 16th, 2006 01:32 AM #1i have a bmw 1989 5series with M20 2.5L inline 6 RWD
Problem is the engine is overheating if i don't put water every 3 days.
Mahina pa ang hatak.
i brought it to european motors and they diagnosed it.
the result is the engine has to be overhauled and the cylinder head has to be replaced. the price is too expensive.
Now i am currently finding a surplus engine. But to no luck in finding a good surplus engine.
I am also considering an engine swap even with a different brand of engine.
Because its my last alternative if i don't find a surplus engine of bmw. Considering it because the new engines are easier to maintain and consumes fuel much less than the original and the newer engines has more power too.
any advice wood really help and if possibly where and how much will it cost???
looking for Bmw engines M20 or higher for a much efficient fuel consumption.
looking for other engine make that will fit my car.
- Dec 2005
- 50
August 16th, 2006 04:11 AM #3umm . . . i suggest having it diagnosed at another place for a second opinion - if not casa, try autosport beside prestige bmw. naji, the owner is very well rounded with engines and has lots of connections with regrads to parts . . . he even does tune ups for rare cars; so bmw should not be a problem
as for a swap, i don't recommend swapping it with another car engine
for one, your dme will not recognize the engine anymore - therefore, some important sensors may not be functionable anymore
besides, its a bmw . . . the fact that you are determined to keep the car instead of selling it due to its condition shows your personal liking towards it
- Aug 2006
- 337
August 16th, 2006 10:53 AM #4Overheating has nothing to do with engine overhauling.Run away and look for good,honest shop. You might have a problem with your radiator or water pump if you're loosing water.In case of the engine do a compression test before doing an overhaul/swap.Buy haynes manual for your car and learn it yourself.Don't be fooled.
August 16th, 2006 01:05 PM #5
Try Top Gear in Aurora Blvd. Do you mind telling us how much is everything going to cost? You might want to consider selling the car as is then just buy a new one. A friend of mine had his dme soaked with water and just decided to sell the car to bmw libis instead of spending 100k to fix everything.
August 16th, 2006 02:14 PM #6
Baka sobrang warped na cylinder head kaya kailangan i-overhaul...
Why not scout for an engine sa ibang country (ebay) and arrange for shipment, baka mas makamura ka... One of our customers did that when he needed to change the block of his E39 525, he saved more than 50% compared to pagawa dito.
August 16th, 2006 04:36 PM #8
AFAIK
sealed & pressurized ang cooling system ng BMW 5-Series... why are you putting in water every three days? did you get a cooling system leak before then overheated the engine causing damages to your cylinder head.
FrankDrebin Guest
- Aug 2006
- 3
August 16th, 2006 05:00 PM #10ok, i will get a second opinion from the shops you guys recommended.
the previous owner of this car probably did not take care of the cooling system therefore the cylinder head might have been warped..?
The quotation from European motors in libis estimated up to 224000, all part change from pistons to almost everything. machine shop. cylinder head SURPLUS not included.
They showed me the result of the compression test and some of the cylinders aint reaching above 6, if i remember correctly i think 2 of them then the other is above 7.
The quotation came from their old files, it was a record from the previous owner. Now i am the one dealing with the dilemma.
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
