Results 1 to 11 of 11
    May 2007
    question lang mga sir, ano ang magiging sira ng sasakyan kung palaging namamatayan ng makina ang nagdadrive? starter?
    maraming pwede cause nyan.
    can you elaborate a little more on how it happens?
    naka manual tranny ka ba?
    May 2007
    Yup manual transmission.
    Yung wife ko kasi just learned to drive. E minsan pinagpapraktis ko siya sa car namin. Palage siya namamatayan, mga more than 10x. I was just thinking kung nakaksira ito ng sasakyan.
    ayun naman pala practice driving pala. talagang mamamatayan yan lalo na pag di timplado yun clutch sa gas. I would suggest that you show her first why we need to step on the clutch before we shift and why we have to release it slowly when she is on first gear. di naman makakasira yan baka lang humina ang battery at di na mag start... ;)
    May 2007
    Quote Originally Posted by afrasay View Post
    Di pa kasi siya sanay magtimpla ng clutch at gas. hehe.. worried lang kasi ako na baka masira yung car..
    thanks anyway.
    Jul 2006
    Just make sure practice kayo sa kung saan wala masyadong sasakyang dumadaan para safe kayo at di siya kabahan masyado na baka mabunggo kayo
    May 2007
    Quote Originally Posted by mbeige View Post
    ako ang ninenerbiyos hindi siya...
    Quote Originally Posted by hops View Post
    hi hops!the starting system is designed to crank the engine several hundred times no matter what. but it its electrical (carbon brushes, armature assembly, etc) and mechanical components (shaftings, bushings, etc) will wear out in time...
    in practice driving, the important thing to do is to wait for at least 15 seconds each time the engine dies before cranking the engine again. the rationale lies on the fact that the flywheel ring gear will still spin (owing to momentum) for a few seconds when the engine dies all of a sudden.starting (cranking) the engine too son will mesh the starter motor's pinion gear with the rotating flywheel. this may damage both 'teeth' pretty quickly...hope this helps.
    Quote Originally Posted by mangdencio View Post
    cool! very informative
    Nov 2003
    it might be driver error lang... or if you want have the clutch adjusted so di ka mahirapan.
Palaging namamatayan
