Results 21 to 30 of 30
- May 2005
- 28
May 30th, 2006 04:41 PM #21si ervin aka Pajoz imus din siya nag meet na ba kyo nyll?
ito nga may problem pa ako sa ride laki naggastos ko but di pa rin nakuha ang problem may thread ako kkapost ko lang bka may maitutulong ka....thanks.
May 30th, 2006 04:51 PM #22
Di pa kami nag meet ni Pajoz pero nagkausap kami via phone. I will send you a PM regading sa problem mo sa isang thread.
- 441
May 30th, 2006 04:52 PM #23Originally Posted by stortaliz888
- May 2005
- 28
May 30th, 2006 04:59 PM #24sir nyll, thanks...
sir nikko m, what i did is on the bottom of inclinometer there is a tiny hole sealed sya at pwede mong butasin. try to look a small metal screw to expand the hole so that you can easily refill the oil. as soon the you fill it lock it by screw and mightybond then dry for a few minutes... ayos na...
- May 2005
- 28
May 31st, 2006 10:16 AM #26sir kcboy,
I don't know the exact amount estimate measurement lang ang ginawa sinilip k muna sa brother inlaw ko. Actually i did is almost full at binawasan ko lang ng kunti to play the needle of inclinometer.
May 31st, 2006 08:34 PM #27
Sir KC boy,
Talked to the Pajero expert joseph. You can refill the hole, medyo matigas nga lang ang sealant, so mga gauge 18 or 19 hypodermic needle ang kailangan mo, then you can seal it again. Also, the usual location of the leak daw is the screw sa ilalim the inclinemeter. you can seal this with any sealant para di na mabawasan ang oil.
hope this helps. And thanks, nyll. will try that, kaso inclinemeter lang kailangan ko eh.
June 7th, 2006 12:48 PM #28
Bros un tire pressure guage ko di ata gumagana. pina lagyan ko sa gasolinahan namin ng hangin un gulong 27 lahat pero sa in dash guage may 31,28,26 at 25 ni isa walang tumama. Langya kumbaga sa best of seven ng NBA SWEEP!! naayos pa ba yun?
- Mar 2005
- 9
June 8th, 2006 07:03 AM #30
oliver: i don't trust the TPMS that much. may araw na accurate siya, may araw din na hari ng sablay. it's an approximation anyway, you're better off with a mechanical gauge. naayos pa ata yan, pero sa banawe. forgot the place though, natanong ko yun dati sa service advisor namin sa quezon ave and fairview...
zales: try niyo sa SP international, bestcolt (both at banawe), mitsuprime, el dorado. they specialize with mitsu parts.
Xiaomi E-Car
