Results 1 to 10 of 12
June 6th, 2007 10:13 AM #1
Anu ba ibig sabihin pag yun 2 front wheel ng 4wd indicator ng pajero blink?
anu pa ba mga indicator sa 4wd na pwede umilaw?
[] -- [] < meaning ng blink? steady lit?
[ ] < umiilaw ba 'to?
[] -- [] < steady lit (normal 2wd), how about blink?
thanks.
June 7th, 2007 12:03 AM #3
Blinking front wheels: means that the 4wd is not completely disengaging. Usually a vacuum or solenoid problem (do a search here, na-discuss na ito). In the meantime, just put in in 4H so it won't tire itself trying to disengage. In this mode, you have a 4wd system similar to the new Suzuki Vitara, most Land Rovers, RAV4, etc.
The rear wheel icons never blink, they only turn off when you put the transfer gear lever into NEUTRAL
The center orange square is the center diff lock. Used for off-road conditons only. Engaged by shifting into 4Hlc and 4Llc.
June 7th, 2007 10:02 PM #4
i can't find the link similar discussion. anyway, how about if it blinks erratic? diba normal blink nya hindi mabilis? what if mabilis parang xmas light? baka siguro sensor or may ground/contact?
how do i use the 4wd lever? btw m/t.
thanks
June 10th, 2007 03:04 PM #5
The only time it should blink is when changing from one drive mode to another. And even that is only momentary (less than 30 secs). If it blinks continously, it doesn't matter if it's fast or slow, you have to troubleshoot the sytem.
2H-rear wheel drive
4H-all wheel drive (can be used on paved roads)
4Hlc-four wheel drive center diff locked (off-road use only)
N-neutral (for use if you have the OEM winch - not offered locally)
4Llc-four wheel drive center diff locked low range (off-road use only when you need double the torque but half the speed)
You can shift from 2H to 4H at speeds up to 100kph
You need to be stationary to shift into 4Hlc or 4Llc.
June 10th, 2007 03:36 PM #6
^ thanks for the instruction on how to use.
Btw, it blinks continuously. normal blink intervals and fast ones (i think the problems is electrical or sensor)... any diy to troubleshoot it? or a shop knows how to fix this problem?
June 10th, 2007 08:25 PM #7
Look for the Joseph Atotubo thread. He knows how to fix these things. On my rig, I just left it in 4H for a month. When I went back to 2H, the blinking nightmares were over.
June 11th, 2007 12:36 AM #8
I'll look for that thread. btw, could the flood water damage sensor or something? just drove it this afternoon and no blinking of whatsoever...
btw, i already tried putting it in 4wd mode still blinking...
yung 4wd system ba ng pajero mechanical ang co-control? meaning kahit sira yung mga sensor eh gagana parin yun 4wd yun nga lang hindi mo mlalaman? kung sira sensor pano malalaman kung naka 4wd aside from the t/f lever? thanks! big help.Last edited by ineedmorehp; June 11th, 2007 at 12:42 AM.
June 12th, 2007 01:56 PM #9
Baka makatulong sa iyo 'to"
http://4wd.blogeasy.com/article.view...ticleID=318776
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
