Results 11 to 12 of 12
June 13th, 2007 12:33 PM #11yung 4wd system ba ng pajero mechanical ang co-control? meaning kahit sira yung mga sensor eh gagana parin yun 4wd yun nga lang hindi mo mlalaman? kung sira sensor pano malalaman kung naka 4wd aside from the t/f lever? thanks! big help.
If anything fails in the system, it will default back into 4wd because it has a failsafe built in (e.g. if the sytem fails off-road). I guess all those years in Dakar does pay off.
The other way to know if power is being sent to the front is by lifting all four wheels.
December 12th, 2007 02:58 PM #12
'Di na siguro ako mag-oopen ng bagong topic. Join na lang ako...
Question po: Is there any store na nagbebenta ng sticker or bagong handle for the transfer lever? Wala na kasi 'yung nakadikit sa paj na dala ko and I'm new to 4wd vehicles so clueless ako kung ano gagawin.
Also, since wala 'yung diagram sa lever, I'm guessing. I have the lever set to the lowest dahil 'yun lang 'yung malakas 'yung hatak and the only light i'm seeing is the c/d lock which is blinking erratically. should i be worried? I'm planning to see mr a22bo if needed, just give me the go signal.
I hope hindi magulo 'yung explanation ko. Anyway, I can further elaborate this if needed.
Thanks in advance!
I've tried hunting for a pic of the lever. itong attached pic ba 'yung itsura non?
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
