Results 1 to 12 of 12
    Anu ba ibig sabihin pag yun 2 front wheel ng 4wd indicator ng pajero blink?
    anu pa ba mga indicator sa 4wd na pwede umilaw?
    [] -- [] < meaning ng blink? steady lit?
    [ ] < umiilaw ba 'to?
    [] -- [] < steady lit (normal 2wd), how about blink?
    thanks.
    up ko lang
    Blinking front wheels: means that the 4wd is not completely disengaging. Usually a vacuum or solenoid problem (do a search here, na-discuss na ito). In the meantime, just put in in 4H so it won't tire itself trying to disengage. In this mode, you have a 4wd system similar to the new Suzuki Vitara, most Land Rovers, RAV4, etc.
    The rear wheel icons never blink, they only turn off when you put the transfer gear lever into NEUTRAL
    The center orange square is the center diff lock. Used for off-road conditons only. Engaged by shifting into 4Hlc and 4Llc.
    i can't find the link similar discussion. anyway, how about if it blinks erratic? diba normal blink nya hindi mabilis? what if mabilis parang xmas light? baka siguro sensor or may ground/contact?
    how do i use the 4wd lever? btw m/t.
    thanks
    The only time it should blink is when changing from one drive mode to another. And even that is only momentary (less than 30 secs). If it blinks continously, it doesn't matter if it's fast or slow, you have to troubleshoot the sytem.
    2H-rear wheel drive
    4H-all wheel drive (can be used on paved roads)
    4Hlc-four wheel drive center diff locked (off-road use only)
    N-neutral (for use if you have the OEM winch - not offered locally)
    4Llc-four wheel drive center diff locked low range (off-road use only when you need double the torque but half the speed)
    You can shift from 2H to 4H at speeds up to 100kph
    You need to be stationary to shift into 4Hlc or 4Llc.
    ^ thanks for the instruction on how to use.
    Btw, it blinks continuously. normal blink intervals and fast ones (i think the problems is electrical or sensor)... any diy to troubleshoot it? or a shop knows how to fix this problem?
    Look for the Joseph Atotubo thread. He knows how to fix these things. On my rig, I just left it in 4H for a month. When I went back to 2H, the blinking nightmares were over.
Pajero 4wd indicator
