Results 1 to 10 of 99
Tsikot Member Rank 3
- Dec 2002
- 551
June 22nd, 2005 11:42 PM #1hope for anybody's idea what would be the cause. Vehicle is a Pajero, automatic 1999 model, 2.8 diesel engine, mileage is at 53,000km
Here's the problem hard starting siya sa umaga. As long as it had stayed overnight parked. After I put the key and turn it I wait for the heater light to dissapear then I start the car. Now here's the weird thing the cars starts then after a few seconds like 10 to 20 seconds the cars starts to shake, smokes white smoke and dies. After this the real problem starts when I try to restart it takes a long time for the engine to start. I just keep on cranking the engine but it does not want to start. And when it finally starts the whole cars shakes and smoke a lot of white smoke and also dies. For me to make the car run and not die again , I have to step on the gas rev it at 1k. But the rev at 1k fluctuates between 800 to 1k. Its like I am stepping on the gas and releasing then stepping but in fact naka pirme lang ako. And at this stage the whole cars smoke even more white smoke and shakes. This takes at least 2 to 5 mins evertime I try to start the car. Now what could be the problem. This started a day after the summer has ended. Or when the temperature in the mornings started to become cold.
some of my thought and diy to fix the problem but failed
1. carbon cleaning after having it done I have my fuel filter changed still the same.
2. Before having the fuel filter change about 2 months ago and 200 kms before I used biodiesel with a concentration of 80%. The whole carbouy was filled in the tank when the fuel light lit up. around 20liters sa carbuoy and less than 10 liters sa tank.
3. I thought it could be the heater plugs ? Had then changed at 25k km ago but the cars starts naman pag 1st try and just dies afterwards. Kaya I ruled this one out.
4. Thought it could be overhaul kailangan na . But wala naman oil consumption and the oil is new around 500km palang.
am out of ideas whats your thoughts
June 23rd, 2005 12:27 AM #2
I'm not sure but you can also check your fuel injection nozzles. puwede ring glow plugs din, parang kulang sa init, kaya it starts and dies, kasi when I went up to Baguio last December ganun din nangyari sa akin. but when I got back to Manila okay na naman.
- Dec 2002
- 551
- 214
June 23rd, 2005 12:35 AM #4na check muna ba engine valve mu? tska mga valve seal? bka may singay na kaya may white smoke, try mu lng pabukas and have it checked, bka yun na yun.. :D
- Dec 2002
- 551
June 23rd, 2005 09:14 AM #5Originally Posted by falken_09
salamat sa reply sir, sige po try ko muna ang heater plugs bago ang top overhaul. sa mas mura muna
June 23rd, 2005 09:42 AM #6
It's gonna be a strike-out process:
Try to check first your glow plugs again (did you use OEM or replacement?). Also, go over to a diesel center to have your injection pump, and nozzles checked as well (maybe they can also do an engine compression test).
June 23rd, 2005 12:45 PM #7
i had the same problem with my 2.8 pajero very recently and solved it by changing the glow plus, glow plug sensor, and finally the fuel filter. It took me two weeks of trial and error to get it. At the end, its just the fuel filter (barado na pala).
- Dec 2002
- 551
June 23rd, 2005 12:59 PM #8Originally Posted by vinj
baka nga glow plugs. had them changed 2 years ago. I hope its original ang it was replaced sa union motors ko pingawa. Thanks for the suggestion will go to a diesel center to try to elinimate the problem
- Dec 2002
- 551
June 23rd, 2005 01:04 PM #9Originally Posted by woodfire
Nakita ko nga din sa brochure na meron, kaso sabi nung service advisor, kapag J DAW auto down lang...
