Results 1 to 10 of 17
- Jun 2005
- 73
September 4th, 2005 05:16 AM #1mabilis ba mapundi ito? binigyan kasi ako last 1Q 2004, then before mag end 2004, napundi driver side so pinalitan. then kanina nung pauwi ako, passenger side naman. sayang, gustong gusto ko pa naman lakas ng ilaw nito, maliwanag kahit tinted windshield ko and ang lakas ng bright, perfect for out of town trips.
all stock pa rin ang wiring harness at socket ko, no added relays. ito kaya ang cause or sa bulb lang talaga? Adventure gas pala auto ko.
September 4th, 2005 09:48 AM #2
thats weird, genuine osram h4s are very durable, umaabot pa nga ng 5 yrs yan. di kaya fake yan or the bulb was improperly handled like touching the glass part
September 4th, 2005 07:13 PM #3
check mo din connectors mo. baka may loose connections. matibay talaga ang osram o as blue said baka fakekis yan nabili mo.
- Jun 2005
- 73
September 5th, 2005 02:51 AM #4bigay lang ito sa akin ng kakilala ko na may shop sa del monte ave. napundi kasi yung low beam ng stock bulb (passenger side) ko kaya nagpunta ako doon. sabi niya, ito daw yung pinakamalakas na Osram na hindi fake. yung tao na rin niya nagkabit. and parehong low beam lang yung napundi, so malamang hindi nila nahawakan yung glass part.
paano ba malalaman kung fake ang Osram or not?
and bakit laging low beam ang napupundi? may problem kaya sa electrical ko? paano din po i check?
- Jun 2005
- 73
September 10th, 2005 02:39 AM #5posted some pics, can someone here say if they are fake or not? thanks.
September 10th, 2005 09:34 AM #6
well they look genuine...at least the packaging looks like genuine osrams..
- Jun 2004
- 1,311
September 10th, 2005 09:44 AM #8Unless you are absolutely sure that the glass part of the bulb was never touched most likely the bulbs were mishandled, possibly leaving some oils from someones fingers on the glass part which led to their premature failure.
September 10th, 2005 11:34 AM #9
when you upgrade bulbs, doesn't it follow that you have to at least add relays?
September 10th, 2005 12:11 PM #10
unless your stock headlight bulbs were 100/80 watts, you might benefit installing relays.
I have had my car's headlight bulbs upgraded to 100/80watts with bosch relays. No problems encountered (yet).
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
