Slow kangaroo!
Sean, if you want to experiment. Remove the whole spark plug para walang compression resistance, the injector signal para walang fuel, the whole tension wire and tape the whole on the cap para walang arching.
If you want to go further shut the running mate piston and do the same as above. Do the sa pababang road para may momentum ka. Goodluck!
