Results 1 to 10 of 19
October 28th, 2006 11:52 AM #1
hello fellow tsikoteers,
tanong ko lang, recently kasi i tried to check yung oil level ng car ko. so while the engine was running, i took the dipstick out, to my surprise there was oil on the whole length of the dipstick. so pinunasan ko and i tried again, pag alis ko ng dipstick the whole length of the stick was again covered with oil! can anyone tell mo kung bakit ganun? is it because the engine was running?
di ko tuloy maread ng tama yung oil level.
thanks in advance.
October 28th, 2006 12:07 PM #2
bago mo silipin ang dipstick siguraduhin nakapatay ang makina ng sasakyan mo... kung gusto mo ng accurate reading ng oil level hayaan mo muna nakapatay ang makina ng sampung minuto bago mo hilahin at tignan ang dipstick...
October 28th, 2006 12:21 PM #3
the best time to check your oil level is early morning before you start your car and on a level ground (not inclined)
hindi magiging accurate ang reading mo kung nakabukas/umaandar engine kasi nagsi-circulate yung langis eh
October 28th, 2006 08:41 PM #4
ok thanks guys, pero could that indicate na may problem kung yung dip stick covered ng oil? o engots lang ako kanina?
October 29th, 2006 12:10 PM #6
- 441
October 29th, 2006 03:56 PM #8
Here we go again...
Check it at operating temperature with the engine off for a few minutes. From there it should read between max and min, better at max of course. Thanks to Blink for this info
October 29th, 2006 07:50 PM #9
the oil dip stick tube extends down to the oil sump so it should be ok to check the oil level with the engine running. check for excessive blow-by, maybe there is too much positive crancase pressure and it is pushing the oil up the tube.
October 29th, 2006 08:23 PM #10
