Results 1 to 10 of 25
May 12th, 2006 12:36 PM #1
Anyone has and have tried this OBDII Scan Gauge with local released cars?
How was it? What data can you get? Do you know where we may get this locally?Last edited by Autobeat; May 12th, 2006 at 12:49 PM.
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 13th, 2006 11:08 AM #2what will you use it for? on a honda? make sure it comes with the correct socket. pre-vtec3's did not have the regular obdII port and only came with the 3 prong socket.
you won't be able to adjust anything tho... maybe monitor lang.
we've got a more complicated version of that in the shop which we use on cars that need resetting.
May 13th, 2006 12:09 PM #3
Thanks, speedyfix. Was planning one lang sana for the Gen2 Rav. Check it naman to have an OBDII port already. Yes, wanted it for monitoring lang sana. Do you know a place that may be selling this, or a similar gadget?
Inquire lang din on the version you have on your shop. What services can your shop do to a car with it? Thanks.
- Nov 2003
- 3,849
May 14th, 2006 12:47 AM #4you might be better off ordering it in the US. alam ko the most basic obdII readers retail for about $4-600. the one in the shop is a little less than $4,000.
you can check the site:
http://launch-techs.com
this is the unit we have:
http://www.launch-techs.com/x431/
andyan narin features nya. iba iba depending on the car tho. sa mga benz and bmw super dami pwede gawin. from the interior and radio of the cars to checking and sending signals to specific sensors to check if they are working correctly.
on the xtrail you can advance timing which make it even more fun to drive.
on a honda all you can do is reset the box and monitor different things.
pretty complicated to explain exactly what it can do pero if you're interested you can read the site.
May 14th, 2006 01:58 AM #6
Thanks, speedyfix. Am hoping it is or will be sold locally somewhere.
OT. Will send you na lang din a PM re: services possible in your shop. Thanks.
- Nov 2003
- 3,849
- Apr 2006
- 375
May 15th, 2006 09:40 AM #8those things sell like hot cakes. ubos na lahat ng kanilang first production run. next production will be may06. its a nice gadget to have so you can monitor a lot of things: revs, fuel consumption, outside temp, etc. as long as you have an obd2-compliant socket, which all cars post-1996 should have.
- Apr 2006
- 375
May 15th, 2006 11:10 AM #10Originally Posted by KoKoNAT
Mazda 3 is incredibly tempting, unfortunately the hybrid is not included in the coding exemption...
All New Toyota Corolla Cross
