Results 1 to 3 of 3
    May 2010
    Mga boss, patulong naman po sa problem ko sa Mitsubishi Adventure/2006/GLX/Diesel. I notice na may vibrating sound siya habang naka-idle. nagtitrigger yung "vibrating sound" everytime na tumunog ng "click" yung aircon. Nawawala din nman ito after mga 5 to 8 seconds. Then magsisimula na nman ulit after tumunog ng "click" yung aircon.
    Nawawala yung vibrating sound once na I turn off the aircon. Nawawala din itong vibrating sound if I will step on the gas pedal. Any suggestion po before dalahin ko sa mechanic? Thanks in advance po sa mga inputs galing sa inyo.
    Bembol
    Oct 2009
    Check the aircon compressor for looseness in its bracket, also check the exhaust pipe, especially near the connection between the exhaust manifold and exhaust pipe (also called exhaust neck), this is prone to cracking with would lead into a rattling sound when idling.
    aircon is an additional load sa engine. mukhang mababa ang menor kapag naka-on ang air-con. have it adjusted.
Vibrating Sound ng Mitsubishi Adventure/2006/GLX/DIESEL
