Results 11 to 20 of 29
Toyota is my choice
- Aug 2005
- 2,063
December 10th, 2005 02:40 AM #11Originally Posted by leinahtan
Originally Posted by leinahtanLast edited by finchy18; December 10th, 2005 at 02:48 AM.
Toyota is my choice
- Aug 2005
- 2,063
- Jun 2005
- 215
December 10th, 2005 03:52 AM #13Originally Posted by finchy18
December 10th, 2005 08:12 AM #14
ang downside lang naman ng pag-alis mo ng thermostat na yun ay medyo matagal lang uminit ung makina mo lalo na sa cold "baguio" morning..although it will start, pero minutes lang naman ang naman ang difference in reaching the engine's working temp when you start to move your ride...pero since ang pilipinas di naman katulad ng ibang countries of origin ng cars natin, ok lang wala na yun, since tuloy-tuloy na ung tubig, minimal na chance mong lumagpas pa sa 1/2 ng temp. guage yan..
so take note:
1.make sure your radiator is clog-free.use 1-3 bottles of radiator flush depending on your radiator's rust content.drain then pour one bottle at a time,run the engine for 5-10 minutes, drain again, then fill with tap water partly open the drain when full, then start the engine...repeat this procedure until the water comes out of the drain is as clear as the water you put in..or a quick way is go to your suking radiator shop, ipasalaksak mo yang radiator mo to remove the rust physically..
2.make sure of tight fittings
3.replace or remove that thermostat and check your radiator cap.
4. check mo kung maganit na ang ikot ng waterpump mo...if so, papalitan na yan ng bearing para smooth ulit ang pag-pump nyan.
December 10th, 2005 08:44 AM #15Originally Posted by finchy18
bb) no idea on the thermostat. my prev car corolla xl encountered the same problem and it was resolved just by performing the above item (aa).
cc) while revving, if your rad is clogged as i have mentioned in my prev post, by observing the water motion from the top opening, it will produce ripples and the water as you said is green due to coolant dye will become hazy.
Hope this helps.
December 10th, 2005 09:37 AM #16
dude,
just my opinion...patanggal mo na yung thermostat mo...hindi kailangan sa pinas yan...tas replace your cap with the same pressure capacity as your stock rad cap. tapos check for leaks.
Toyota is my choice
- Aug 2005
- 2,063
December 10th, 2005 12:22 PM #17Originally Posted by leinahtan
applicable bah mag pa clean ng radiator gamit ang rod pra sa fiber glass na radiator (disposable type) ?
ano po yung "pasalaksak"? cebuano po me sir di ko naintindihan mga malalim na tagalog.. =)
thanx sir!
Toyota is my choice
- Aug 2005
- 2,063
December 10th, 2005 12:25 PM #18Originally Posted by alwayz_yummy
ahh i see..
December 10th, 2005 12:29 PM #19Originally Posted by finchy18
pasalaksak - ang pagkakaintindi ko dito eh pabaon, pasubsob, etc...
Toyota is my choice
- Aug 2005
- 2,063
December 10th, 2005 12:38 PM #20Originally Posted by umzzzzz
flat rod daw po pra pang linis sa vertical jackets ng radiator..
pabaon, pasubsob.. di ko talaga na gets po.. (sorry) :confused:
Xiaomi E-Car
