Results 1 to 14 of 14
    ung wipers ng innova ko medyo maingay pag nag-ooperate, meron syang parang scrapping sound. I replaced the stock wiper blades ng banana type wipers pero maingay pa rin. ano kaya ang problem at pano ko maaalis ung ingay. thanks.
    Sep 2005
    ilang taon na sir yung innova? pa polish nyo yung windshield..
    kung yun mga cheap generic wipers pinalit mo, talagang ganyan, you should have replace it with Bosch or other branded wipers...assuming hinde sa windshield problema ha
    I experienced the same recently...Changed my wipers pero maingay parin...clean my windshield with kerosene and rubbing compound pero ganun parin...finally after close inspection, (pinaandar ko wiper na nasa labas ako) hindi pala sa wiper mismo galing yung ingay, sa wiper brackets connected sa wiper motor under the hood/windshield area...after cleaning using WD40 and lubrication using oil...okay na sya ulit...Parang walang nagyari!
    Seven years na sir ung innova, mukhang kailangan nga ipolish ung windshield-marami na water marks. any idea kung magkano pa-polish?
    Quote Originally Posted by mateomarco View Post
    sir alin ang lalagyan ng WD40, un bang mismong bracket?
    un nga ang binili ko sir, mukhang ung windshield nga ang problema.
    Jun 2012
    Quote Originally Posted by KEG View Post
    Check Big Berts http://www.bigberts.com/prices.htm
    Windshield polishing starts at 350.
    Yes sir...sa brackets na naghohold from the wiper motor to the wiper arms below the windshield under the hood...
    Sep 2008
    Try to lift both wipers and turn it on, pag maingay pa rin, then hindi wiper blades and windshield ang problem. It could be the pivot joint of the wiper linkage that needs an overhaul
    Nov 2007
    Quote Originally Posted by jakewise View Post
    Sir kung pag lift ko both wipers ay wala nman ingay, so most probably ba ay sa windshield ang problem??
    Kasi napansin ko minsan pag sobrang lakas ng ulan ay nawawala na yung ingay den bigla na lang babalik after a few days.
    Apr 2009
    That is the problem when you put water-repelling agents on your windshield (eg Rain-X, etc). It will make your wipers jump...
    ^ looks like it. part of the reason why i prefer not to apply them on our cars' windshields (although i admit i've been tempted more than once)
    Sep 2008
    Quote Originally Posted by Excalibur View Post
    Kapag nawala ang ingay when you lift your wipers, it can be two things; wiper blade or windshield has a lot of grime. It is easy naman to clean the windshield well, so you may do it step by step to avoid a big damage on your pocket. HTH
Noisy Wipers
