Results 1 to 10 of 32
- Jun 2007
- 25
July 13th, 2007 08:52 PM #1Between Nodalos and MufflerLand,who makes better headers,mufflers,and exhaust systems?Also,if you have others that you may wish to recommend,please do so.
THANKS in advance.
July 15th, 2007 12:36 AM #4
July 15th, 2007 04:43 PM #5
Sobrang ganda ng gawa ng Mufflerland Morato. May mandrels, may TIG welding, etcetera...
Ito, gawang Mufflerland:
Aluminized bends done in shop.
Mandrel bends done outside (no 2.5" stainless in shop, so I had to buy outside) then TIG welded in-shop. Gandaaaaah ng welds.
They have a good selection of mufflers. I bought a locally made one there for half the price of an original one, and the construction is almost as good as the Japanese one.
July 16th, 2007 08:11 AM #8
It's arc-welding (watched them do it), but without the rod of solder they usually use.
Sobrang pino ang welds ng gawa nito, and it's much better than acetylene torch or regular arc welds... more accurate, not as messy... but it's expensive. It's the same welding technique they use on bicycles.
July 16th, 2007 08:52 AM #9
Im sorry! Have to correct
MIG means Metal Inert Gas a.k.a GMAW gas metal arch welding.
Electrode (wire) and shielding gas comes out from the gun fed by the machine. Parang arch welding without clamp and welding rods nasa gun na lahat ng operation.Last edited by 4JGtootsie; July 16th, 2007 at 11:36 AM.
July 16th, 2007 09:01 AM #10
May clamp pa rin, actually, for the ground... you can't arc weld without current flow. At least, ganyan sa welder nila.
Pero wala nang rods... ang galing at ang pino ng gawa...
Parang ang sarap bumili ng machine... kaya lang... mahal! Mga 70k daw!
Sec. Dizon and RSA seem to have a really good working relationship, btw.
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
