Results 11 to 13 of 13
December 28th, 2007 11:17 PM #11
thanks for the advice... will consider all your suggestions... thanks again...
- Sep 2007
- 215
December 30th, 2007 07:11 PM #12usually kung kumukulo yung radiator mo ... blow by na yung engine mo .....
check mo kung may tulo ng tubig sa parking spot mo ... kung wala bad news ... overhaul na yan ...
kung may tulo ng tubig ... water pump ... leaking radiator ... or need to replace your radiator cap or your radiator hose
another problem is your thermostat mura lang naman orig niyan mga 750 ... or check mo yung mga auxiliary fan mo kung nagautomatic on ba sila if not that is your culprit
if you like drop by in the shop and let my mechanic take a look
BANAWE AUTO SUPPLY
7120115
regy
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 1st, 2008 12:17 PM #13the idling and heating problems are different. idling is probably the servo. the cooling system probably a clogged radiator.
high idle RPM at engine start
