Results 1 to 9 of 9
    Sep 2006
    guys help naman magpapalit kasi ako ng headers B16a engine kaso yung stock na headers (4:2:1) yung sensor nya lilipat ko sa (4:1) na headers hindi ko kasi alam kung pano yung tamang position kung san ko lalagay yung 2 O2 sensors nung stock na headers (4:2:1) pag lilipat ko na sa (4:1) na headers? thanx
    Oct 2004
    O2 sensors ng Honda, sa isang tube lang po nakalagay as far as a i can remember... Put it sa header ng 4th cylinder...
    Sep 2006
    bali po isang sensor nalang po ba gagamitin ko? or yung 2 na O2 sensor lalagay ko dun?
    Aug 2004
    Quote Originally Posted by thermaltake View Post
    How are the two sensors used on the stock unit? Just put one in one of the primaries and the other right after the collector. If you leave one out, it will cause a check-engine light.
    Oct 2004
    err... what generation of B16a is it? some JDM B16a only have 1, some have 2 O2 sensors nga....
    Sep 2006
    im not really sure kung anung generation ng B16a po yung nasakin, but theres one thing for sure that 2 O2 sensors has gave me alot of headaches alin po kaya dun sa dalawang sensors ang lalagay ko sa primary kasi yung isa po have a green terminal and the other one is white alin po kaya dun yung sa primary and sa collector, or ok lang po ba na magkabaligtad yung 2 na sensors?
    Aug 2004
    Agh. You'll have to go to the local Honda club boards to find out... doesn't the garage which did the swap know?
    You shouldn't switch them, AFAIK, although I don't know how bad the effect will be.
    Nov 2003
    have it installed in the same location it was installed sa stock header.
    Aug 2006
    papalya yan pag napag-switch mo yung positions. sobrang mararamdaman mo pag hinde pa mainit yung engine . happened to a friend of mine.
need help B16a O2 sensors
