Results 1 to 9 of 9
January 2nd, 2005 09:40 PM #1
when i had my wheels aligned nasobrahan siguro ng higpit pagbalik kaya naputol. ginamitan kasi ng impact wrench. napansin ko lang na putol ng i-double check ko pagdating sa bahay. ng hihigpitan ko sana nalaglag na lang.
is it still safe to drive with one less stud?
madali rin ba itong palitan? sa rear wheel ako naputulan.
January 2nd, 2005 09:42 PM #2
relatively safe siya siguro ng one week tapos daily mo i check kung lumuluwag..pero its better to buy a new one in banawe..what car ba? sakin mazda familia..i buy the wheel studs in autorama in banawe for 180 petot per piece just to give you an idea..
January 2nd, 2005 09:45 PM #3
Happened to my brothers car, front and rear wheels naputulan ng stud. Its not safe lalo na pag high speed driving. Pwede naman palitan yung stud, check out the shops at banawe madami dun.
January 2nd, 2005 10:04 PM #4
di ba pwedeng i-reklamo yan dun sa pinag-align-nan mo? parang CSI hehe i-ma-match yung teeth ng wrench dun sa pinaghigpitan na part..?
January 2nd, 2005 10:14 PM #5
Did they use a machine to tighten the studs? Dapat request mo by hand na lang para di masobrahan.
January 2nd, 2005 10:15 PM #6
dali lang palitan yan. just knock out the remaining piece of the broken stud using a punch and hammer. then pag natanggal na, just insert the replacement stud then pull it in using the wheel lug nuts - just thread in the nut on the new stud and turn it in, mahihila na yung stud. use a washer or two para hindi masira yung lug nuts. when inserting the studs, check if the studs you bought are splined. if they are then make sure the splines are aligned on the corresponding splines in the hole.
January 3rd, 2005 11:47 AM #7
thanks guys. maasahan talaga lagi ang tsikot
although i've already driven it for at least 500 kms nonstop with no problem, i'll play it safe and replace it asap.
January 3rd, 2005 12:08 PM #8
Dalin mo lang sa Eldorado Cubao.
Yung Stud < Php200, labor, kausapin mo na lang yung mekaniko sa harap. Usually P250 singil sakin. Madalas ako maputulan ng stud ng Paje, ewan ko kung bakit.
Reminder lang. Yung stud ng Pajero, contrary to popular belief, maikli lang. Make sure you get the right sized stud.
January 22nd, 2005 02:09 PM #9
Natanggalan na kami ng gulong sa GEN I Pajero dati. Putol ang mga studs. Maluwag kasi ang lug nuts kaya nag-vibrate sobra.
Madali lang naman palitan. Basta tama ang stud na nakuha mo.
Xiaomi E-Car
