Results 11 to 20 of 30
- Feb 2016
- 269
October 30th, 2016 10:15 PM #11Ang ganda iparetrofit ang headlight, ang lake. Hehe
Sent from my Starmobile PLAY Click using Tsikot Forums mobile app
- May 2016
- 80
October 30th, 2016 10:25 PM #12Pa help naman po sa isang conern ko boss hehe
Dami pa pag kakagastusan huhu
Sent from my ASUS_T00J using Tsikot Forums mobile app
- 54,234
November 1st, 2016 10:53 AM #13regarding the slight mis-alignment of the bumper. i can not predict how it can be fixed, because the pictures were in-sufficient. but i strongly urge you to run away from non-regulation fixes. you know, yung mga lalapit na magpiprisintang aayusin siya sa pamamagitan ng mahiwagang screws niya. i tried them before. "they don't work very well under ordinary use." as much as possible, use factory spec. ngayon, kung may taingang naputol, ay... tough luck! you can ask around for a professional who can install mounting tabs from the inside... it's cheaper than replacing the bumper.
lights. check the bulbs for filament breaks, using an ohmmeter and not just one's eyes. also, check, clean, or replace the bulb sockets. they may have already corroded beyond repair because of water seepage.
when i had my headlights replaced (found a seller in olx; RHD models siya, so i stuck some opaque tape on 'em afterward, to reduce glare), the entire procedure took an hour or so. ok lang sakin naman, dahil nasa burger king ako all that time.
good luck, po.
- May 2016
- 80
November 13th, 2016 02:31 PM #14*dr.d normal lang ba if umuulan tapos nababasa ung doon sa likod ng tail lights?
- May 2016
- 80
November 13th, 2016 04:17 PM #15Boss d
yan po. Kasi nagreseal naman ako tapos pinatuyuan ko as in walang moist tapos ngbyahe ulit may moist nanaman di naman umulan
- 54,234
November 13th, 2016 10:05 PM #16hindi normal.
mine have always been dry, even during and after a strong downpour.
dalawa lang naman ang pinanggagalingan ng moisture.
1. may crack ang housing;
2. hindi lapat ang sockets sa likuran.
umiinit kasi ang loob ng taillight and headlight housing, kapag ginagamit.
pagpatay ng ilaw, ay lumalamig yan, at hinihigop ang anumang tubig o moisture sa paligid niya.
the cycle repeats everytime you use them lights.
after some time, there will be enough moisture inside the housing for you to see.
tingnan nyo kung may butas sa likuran ng housing, na puedeng daanan ng tubig.
hinala ko rin, ay kapag basang basa ang rear trunk, ay napaka-moist ng hangin sa loob, at iyon ang hinihigop ng lumalamig na tail light.
- May 2016
- 80
November 14th, 2016 10:14 AM #17So i came with my working diagnosis hehe
Hindi nakalapat ung tail lights sa edge. Ewan ko baka kasi wala na ung rubber nya so di siya fit na fit. Kaya pag umuulan nappunta dian tubig and nagmmoist at mabilis palitan ung mga bulb. Anyway. Kung tama ako, ano pwede remedyo para matakpakan ar hindi pasukan ng tubig? Thanks tsikot!
- May 2016
- 80
November 15th, 2016 09:08 AM #18Tama po ba ung clearance? Hmm?
- 54,234
November 15th, 2016 09:18 AM #19
- May 2016
- 80
November 15th, 2016 09:58 AM #20Ung usual po na way. Ung nasa pic po ba pag umuulan dapat basa ung andian po? Hindi ko alam kung tama ung clearance ng tail light housing sa trunk and bumper or mismong rubber seal nung paglalagyan ng bulb
Is it true na may recall ang yaris cross hev recently regarding sunroof issue? Lol.
China cars
