Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    May 2016
    Is it just my car? Kasi everytime na umuulan nababasa or nagmmoist ung sa loob ng headlights at tail lights na nagccause ng hindi pag ilaw ng mga lights properly like isa lang ung umiilaw. Pag brinight mo nagiging "bulding" ung sasakyan. Pag nagpreno ka isang side lang umiilaw. Kakapalit lang naman ng bulbs. Inoobserve ko lahat ng naka cedia meron talagag moist karamihan. Inputs nyo po? Thanks!
    Sent from my ASUS_T00J using Tsikot Forums mobile app
    Oct 2009
    Quote Originally Posted by Sedanlover View Post
    kaya nag kakaroon ng moist ,may water leak papasok sa loob maaaring hindi na maganda ang pagkaka seal ng Hl mo TL mo.pa reseal mo nalang or bumili ka ng sealicon sealant saka mo lagyan ung palagid na maaring pasukin ng tubig.
    yung akin, wala. tuyo lahat. nguni at binenta ko na.
    yes, have them re-sealed. and while you are it, maybe you should consider re-polishing the headlight clear plastic, inside and out, while they are still open.
    May 2016
    Dba pag tatanggalin ung headlights kailangan alisin ung bumper mga boss? How much po pala ung pareseal pati ung papolish ng headlights and tail lights?
    yespo. tanggal bumper to remove headlight. i couldn't believe it at first, until an aficionado showed me. but it wasn't that difficult at all, if one knew how. marami lang turnilyo.
    i hated that lancer because of that.
    may mga ads sa olx on headlight works. never tried it, 'though.
    May 2016
    What will be the problem if i won't clean and reseal the headlights?
    the opacity will partially block and diffuse the light beaming out of the headlights. the ability of the headlights to light the way for you, will diminish.
    if you open it to clean but did not seal it afterward, water will seep in, resulting in:
    1. fogging and diminished lighting ability;
    2. corrode the brightwork of the reflector, resulting in poor lighting ability;
    3. corrode the metal bulb contacts;
    4. may cause premature bulb filament failure.
    it is tempting to just leave them as is. but you will enjoy the night-and-day difference, once you get them headlights cleaned spic and span, or have them replaced.
    May 2016
    Mura na kaya ang palinis at reseal nun at 500 labor then pabuff 400 each.
    Most likely unahin ko ung sa harap kasi mas grabe. 1.2k? Oks na ba yun?
    May 2016
    Bukas kasi nakasched ako magpaclean and reseal ng headlights boss. May other concern rin ako. Since tatanggalin ang bumper pwede pba to maiscrew? Medyo loose kasi siya. Naka screw nalang ung both sa gilid pero ung iba di nka srcew floating lang.1477832517206.jpg1477832525760.jpg1477832534935.jpg1477832544351.jpg
    Feb 2016
    Ang ganda iparetrofit ang headlight, ang lake. Hehe
    Sent from my Starmobile PLAY Click using Tsikot Forums mobile app
    May 2016
    Pa help naman po sa isang conern ko boss hehe
    Dami pa pag kakagastusan huhu
    regarding the slight mis-alignment of the bumper. i can not predict how it can be fixed, because the pictures were in-sufficient. but i strongly urge you to run away from non-regulation fixes. you know, yung mga lalapit na magpiprisintang aayusin siya sa pamamagitan ng mahiwagang screws niya. i tried them before. "they don't work very well under ordinary use." as much as possible, use factory spec. ngayon, kung may taingang naputol, ay... tough luck! you can ask around for a professional who can install mounting tabs from the inside... it's cheaper than replacing the bumper.
    lights. check the bulbs for filament breaks, using an ohmmeter and not just one's eyes. also, check, clean, or replace the bulb sockets. they may have already corroded beyond repair because of water seepage.
    when i had my headlights replaced (found a seller in olx; RHD models siya, so i stuck some opaque tape on 'em afterward, to reduce glare), the entire procedure took an hour or so. ok lang sakin naman, dahil nasa burger king ako all that time.
    good luck, po.
    May 2016
    *dr.d normal lang ba if umuulan tapos nababasa ung doon sa likod ng tail lights?
    hindi normal.
    mine have always been dry, even during and after a strong downpour.
    dalawa lang naman ang pinanggagalingan ng moisture.
    1. may crack ang housing;
    2. hindi lapat ang sockets sa likuran.
    umiinit kasi ang loob ng taillight and headlight housing, kapag ginagamit.
    pagpatay ng ilaw, ay lumalamig yan, at hinihigop ang anumang tubig o moisture sa paligid niya.
    the cycle repeats everytime you use them lights.
    after some time, there will be enough moisture inside the housing for you to see.
    tingnan nyo kung may butas sa likuran ng housing, na puedeng daanan ng tubig.
    hinala ko rin, ay kapag basang basa ang rear trunk, ay napaka-moist ng hangin sa loob, at iyon ang hinihigop ng lumalamig na tail light.
    May 2016
    Boss d1479018477009.jpg yan po. Kasi nagreseal naman ako tapos pinatuyuan ko as in walang moist tapos ngbyahe ulit may moist nanaman di naman umulan
    pano nyo po pinapalitan ang bumbilya?
    rear tail light ba ito?
    hindi ganyan yung sakin.
    yung sakin, may tatlong sockets para sa tatlong bulbs.
    May 2016
    Hindi nakalapat ung tail lights sa edge. Ewan ko baka kasi wala na ung rubber nya so di siya fit na fit. Kaya pag umuulan nappunta dian tubig and nagmmoist at mabilis palitan ung mga bulb. Anyway. Kung tama ako, ano pwede remedyo para matakpakan ar hindi pasukan ng tubig? Thanks tsikot!
    bro yun pag reseal dyan ginamitin ng heat gun?
Mitsubishi lancer cedia headlights and Tail light
