Results 11 to 20 of 25
January 4th, 2008 06:29 PM #11
for your paintjob, si LexTer nga recommended... PM mo na lang sya. Sa antipolo ang shop nya and also an active airsoft enthusiast. (kaya dami pasa katawan nyan lagi)
January 5th, 2008 02:10 AM #13
uy malapit si lexter sakin ah..d2 lang ako sa may sta.lucia grandmall eh sige check ko sya
January 5th, 2008 02:51 AM #14
January 5th, 2008 09:06 AM #15
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 6th, 2008 07:57 PM #17
yup miguel naka usap na kita last saturday went to your shop and ang ganda ng shop mo wow...at mga customers mo big time gaganda ng kotse
nahihiya tuloy ako dalhin ang CARiton ko sa shop mo eh
pro ayos shop nila
January 7th, 2008 02:00 AM #18
mga peeps nasagot kona ang problema ko, internet lang pla katapat nito
eto nakita ko with my research
http://auto.howstuffworks.com/clutch2.htm
[SIZE=+1]Clutch Diagnostic Test[/SIZE][SIZE=-1]If you find that your clutch has failed, here is an at-home diagnostic test that anyone can perform:[/SIZE]- [SIZE=2]Start your car, set the parking break, and put the car in neutral. [/SIZE]
- [SIZE=2]With your car idling, listen for a growling noise without pushing the clutch in. If you hear something, it's most likely a problem with the transmission. If you don't hear a noise, proceed to step three.[/SIZE]
- [SIZE=2]With the car still in neutral, begin to push the clutch and listen for noise. If you hear a chirping noise as you press, it's most likely the clutch release, or throw-out bearing. If you don't hear a noise, proceed to step four.[/SIZE]
- [SIZE=2]Push the clutch all the way to the floor. If you hear a squealing noise, it's probably the pilot bearing or bushing.[/SIZE]
[/SIZE]
[SIZE=2]
ANG PROBLEM NALANG EH SINONG MEKANIKO ANG MAY ALAM NITO? hihihihi
[/SIZE]
January 7th, 2008 10:29 AM #19
there's a mechanic/shop in pasig who may be able to help you.
tops name ng shop. look for fidel. glorietta street cor. cruz(?) near ortigas extn. 0918-338-4024
January 10th, 2008 03:16 PM #20
naayos napo ang second problem ko ang problem eh yung sa rotor disc assembly nagpalit nako nun pati yung pinagkakabitan ng tire yung may 4 stud sorry di ko alam tawag dun eh
sa RVC motors ko napaayos ok kc ang mekaniko eh yung mismong may ari ng shop
I think they took over Sept 2023... I remember their event presented the 296 GTB and the Purosangue...
Car Sales Data (2024)
