Results 1 to 7 of 7
    Tanong ko lang po kung me idea kayo kung san nanggagaling yung sound (tikitik sound) tuwing mag-step ako sa gas pedal kapag 3rd or 4th gear na. Pag nasa 1st and 2nd gear, tahimik sya pero once na mag-accelerate ako, naririnig ko yung sound, pag ni-release ko yung gas pedal, nawawala. Btw, automatic transmission po yung auto ko. Thanks
    Nga pala, yung auto ko ay Mistubishi Lancer MX 2000, Automatic transmission, Gas
    Dec 2007
    Did you check your ATF level, sir?
    Quote Originally Posted by woohoo View Post
    yup. my atf is ok. malinis pa sya at tama ang level.
    Hmmm...di kaya engine support problem yan ser? Parang similar jan kasi naging problem ko dati e
    Jan 2009
    Could be engine knock.
    Sir OJ,
    Nung una akala ko din e engine knock yung problema sa akin...tried putting on those additive that says reduce and eliminates engine knock dun sa gas tank ko pero di pa din nawala e...only to be discovered by my trusted mechanic na defective na yung engine support ko...and voila! nawala yung ingay na parang bula nung pinalitan ng engine support! Sabi niya kasi nag-iiba talaga ang rate (or intensity ba tawag dun?) ng vibration sa engine during acceleration kaya dun ko lang sya naririnig pag nag-aaccelerate ako.
    Anyway, case to case din yan...and pwede din nga engine knock yung cause or it can be anything else.
sound when stepping on the gas pedal during acceleration at 4th gear
